Renault Forums :: Independent Renault forum
Notices
Engines Engine/transmission and other oily matters
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... RenaultForums store
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
...   Clio FAQ
...   Espace FAQ
...   Laguna FAQ
...   Oil FAQ
... Garage list
... Glossary
... View our rules
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... vBulletinImg
... Data
... Who drives what?
... Who supports who?
... Ads
Xenon Headlight Adjustment
Engines
Reply
Thread Tools Search this Thread Display Modes
Old 18th February 2010   #1
PitcherP
PitcherP is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Is there anyway that I can adjust my Xenon headlights as when I turn on my dipped headlights you can physically see the beam rise to what appears to be its maximum height. Because of this I am constantly being flashed by passing motorists because they think I am on full beam. Renault Clio 2005.
Phil
PitcherP is offline   Reply With Quote
5 Lastest Threads by PitcherP
Clio 2005 Dashboard Dimmer Switch Electronics PitcherP 0 165 27th February 2010 10:24 AM
Xenon Headlight Adjustment Engines PitcherP 3 521 18th February 2010 02:24 PM
Old 18th February 2010   #2
Laguna01
Laguna01 is
has no status.
Member
Re: Xenon Headlight Adjustment
Xenons should be self-levelling. Not sure how a Clio's self-levelling system works but on a Laguna there's a mechanism attached to the front suspension, could be worth checking to ensure that this hasn't been damaged.
Currently in Laguna01's garage:
Laguna II 1.8 tourer
Laguna01 is offline   Reply With Quote
Old 18th February 2010   #3
Vickery64
Vickery64 is
has no status.
Diamond member
When you turn on the ignition, Xenon headlights cycle through a self check by dipping fully down and then settling into the normal driving position. If a fault is detected the lights stay fully down to prevent glare.
Seeing as your light rise up I would guess that the system is ok but just needs adjusting. This is done in the same way as normal headlights; there are adjusting screws on top of lamp unit. To do this accurately a garage needs to use their equipment but this is a simple and cheap job. A lot of garages do it for free if they need doing on an MOT
Currently in Vickery64's garage:
2001 Laguna II V6 24 valve
Vickery64 is offline   Reply With Quote
Old 27th February 2010   #4
PitcherP
PitcherP is
has no status.
Junior Member
Threadstarter
This seems to have cured itself. I took it to my local garage to have it looked at. He put it on his ramp to check the joints haven't popped out. The ramp was the kind that the wheels are not supported it raises the car on the jacking points. When the car was lowered we turned on the lights and hey presto they lowered and seemed normal. The only assumption I can make is that one of the sensors had stuck and by raising it on the body with the wheels dangling in mid air it freed the stuck sensor. Anyway the lights have been OK ever since. Thanks to you all for your suggestions.
Phil
Reply
Tags
adjustment, headlight, xenon, zen
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright � 2005-2009 RenaultForums
