Laguna 2 - TDC sensor/EGR valve locations
Engines
20th February 2010
#1
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
 I have a laguna 2, initiale, petrol, 16v ide, 03 plate. The management light periodically comes on when the car runs sluggish, as though working on 3 cylinders.
After reading many threads, it is possible that the TDC sensor and EGR valve could do with a clean or replacement. I have been unable to locate these. Please can someone help me find the location of these (in baby language  ).
Currently in psaggu's garage: 2003 Laguna II 2.0L IDE initiale
Sponsored Links
Advertisement
21st February 2010
#2
Super-mod
Nominated 5 Times in 4 Posts
 TOTW/F/M Award(s): 4
My Mood:
Re: Laguna 2 - TDC sensor/EGR valve locations
Hello psaggu  unless someone knows better, I'm pretty certain that EGRs are a diesel only
The TDC sensor is located on the bell-housing by where the gearbox and engine join, I'd like to say they're all a doddle to find, but although I haven't spent a great deal of time looking I still haven't seen the one on mine yet.
In the even that you're not sure what you're looking for I'll put a picture up in a moment.
Pici added
Currently in hondo's garage: 2008 1.6 Meg Tech Run
21st February 2010
#3
cockers is
probably fixing a renault.
Diamond member
hi , your engine , if its an F5R ,( ide) engine , then you do have an egr valve, sitting at the back of the engine , and the tdc is as above.
you should get a diagnostic check/ codes read out first to point in the right direction, as its quite rare for an egr valve fault on these.
where abouts you ?
21st February 2010
#4
Super-mod
My Mood:
 JC! I was convinced that an EGR V was a diesel only part.
Thanx cockers
21st February 2010
#5
Junior Member
Threadstarter
Thanks Hondo and Cockers - this is really great information. Cockers I am in West London near Heathrow.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
