*SORTED* Clio II (2003) Headlight Problem - No dipped Beam, Fuses all OK. - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Electronics
Reply
Thread Tools Search this Thread Display Modes
Old 22nd February 2010   #1
johnson293
johnson293 is
has no status.
Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Question *SORTED* Clio II (2003) Headlight Problem - No dipped Beam, Fuses all OK.
Got a new problem with my Clio II - dipped headlights wont work, and I first noticed it last night.
Side lights work, Main beam works, indicators and front/rear fogs all work - this includes the dashboard lights, however, nothing for the dipped beam - no dashboard light for it either.
I have checked the fuses, and they all seem to be ok. I have checked the bulbs, and they all appear ok and not blown.
Netx thing to check was the relay - however, on opening the relay box cover in the engine bay (next to battery) there is no map to say which relay is which, and I cant find anything in the manual.
Any help would be appreciated - either on which relay it could be that controls the headlights, and whether if this was faulty - would that only affect the dipped beam?
Next thing to try is possibly the switch/stalk incase that is faulty, but that will need ordering a part, so its the simpler things I'd rather try first.
Cheers for any help/advice offered.
MJ
Currently in johnson293's garage:
2004 (54) Vauxhall Astra 1.6 Club
Last edited by johnson293; 22nd February 2010 at 02:19 PM. Reason: typos - sausage fingers!
johnson293 is offline   Reply With Quote
5 Lastest Threads by johnson293
2004 Scenic 1.5 DCi 80 - White Smoke and appears... Engines miggy55 48 13743 1st June 2010 12:29 PM
Clio 1.5 DCi 80 - Intermittant Engine... Engines cream2cream 4 4569 22nd April 2010 04:05 PM
*SORTED* Clio II (2003) Headlight Problem - No... Electronics iulian 3 8802 22nd February 2010 01:56 PM
Hello - I'm new here!! Welcome to RenaultForums scatz 9 757 27th August 2009 10:59 AM
Sponsored Links
Advertisement
Old 22nd February 2010   #2
johnson293
johnson293 is
has no status.
Member
Threadstarter
Re: *SORTED* Clio II (2003) Headlight Problem - No dipped Beam, Fuses all OK.
Sorted - while browsing on here and the web, found out that the Clio II's headlight relay is in a relay box right behind the glovebox inside the car (well tucked away).
Checked that, and one relay was unseated - pushed it back in and voila... dipped beam working again.
MJ
Old 8th May 2011   #3
swalters
swalters is
has no status.
Junior Member
Send a message via Skype™ to swalters
Smile Re: *SORTED* Clio II (2003) Headlight Problem - No dipped Beam, Fuses all OK.
FIXED eventually via youtube video help.
Spent ages troubleshooting and researching same issue with my wife's 2004 Clio Dynamique 16v 1.2 dipped beams not working (main lights; not full beams).
After much time taking out both bulbs, testing them direct from battery, searched many forums etc. All other lights worked except main headlights.
Fixed straight away when I found below link to a youtube video showing how to push the relays back in beneath the glove compartment (stick your head in passenger footwell and look up).
Perhaps would be an idea for Renault to have covered the 'footwell' eh?
http://www.youtube.com/watch?v=spPD9SWJRK4
(if link doesn't work search youtube for "How to fix Renault Clio Headlight Problem")
Hope it helps others out there!
Steve Walters.
Swansea.
Currently in swalters's garage:
2004 Renault Clio MKii 1.2 16v Dynamique
swalters is offline   Reply With Quote
The Following User Says Thank You to swalters For This Useful Post:
wilson002 (29th January 2013)
Old 31st December 2011   #4
iulian
iulian is
has no status.
Junior Member
Hi guys, any help would be much appreciated.
My problem seems similar but not identical.
Quite frequently, my relay makes a clicking sound and the headlights go off but also the dashboard lights and the windscreen wipers, the indicator lights and the hazard lights. Sometimes is just one click and everything goes off (except for the CD player) and other times it is a quick repetitive clicking noise and the lights quickly go on and off.
Checked the relay (identified the one for the headlights, removed it and everything was working fine, except for the headlights of course) As soon as I put it on, the same problem. There are four relays under the glove compartment and I noticed one of them (which is not the one for the headlights) gets a bit more warmer than the others. All of them seem to be properly inserted in the sockets. Any ideas, please?
Forgot to say the clicking sound comes from under the glove compartment.
Currently in iulian's garage:
2003 renault clio 1.2
iulian is offline   Reply With Quote
Reply
Tags
beam, clio, dipped, fuese, fuses, headlight, problem, sorted
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © 2005-2009 RenaultForums
Inactive Reminders By Mished.co.uk and FTP-Anime.com
