Intermittent Starting problems - Renault Megane 1.6 (2006 Model) - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 2nd March 2010   #1
dchetty
dchetty is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
I have a strange starting problems with my Renault Megane 1.6. After driving for about +/- 30 to 45 minutes and if stuck if traffic (not moving) all the time - the vehicle switches off. I try starting it again and can hear the engine spin, but it fails to starts.
If I leave the car off for about 20 minutes, it starts again. I have taken it to Renault who indicate that the following needs to be changed:
1. TDC and loom
2. Crankshaft sensor
3. Map sensor
It costs a lot to have all these replaced and I am not even sure it might fix the issue. Renault could not pin-point the exact fault but informed me that the above sensors needs to be replaced.
I have read on the forum that the TDC can be cleaned and put back on. Would this be a viable option on an 2006 Megane or should I look else where for the issue? What else could be other possible faults?
Many thanks,
dchetty is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by dchetty
High/inconsistent idle - Megane 2 (1.6, 2006... Engines Truckbusuk 1 2544 9th March 2010 07:06 AM
Suspension/drive shaft/cv joint problems Wheels & tyres crestani 1 1890 2nd March 2010 06:11 PM
Intermittent Starting problems - Renault Megane... Engines manonamission 5 13110 2nd March 2010 05:59 PM
Renault Megane 1.6 (2006 Model) Engines madnoel10 2 1560 24th February 2010 10:02 AM
Sponsored Links
Advertisement
Old 2nd March 2010   #2
davesss
davesss is
Calm Cool and Collected
Tourerman
davesss's Avatar
Nominated 0 Times in 2 Posts
Nominated TOTW/F/M Award(s): 3
Re: Intermittent Starting problems - Renault Megane 1.6 (2006 Model)
It,s very unlikely to be the TDC Sensor and Renault should know that !
A dirty TDC sensor only needs cleaning not a £100 pound bill for a new one and the loom, it is an easy job to clean it, the TDC only seems to cause bad starting, once it,s running there is no problem.
__________________
A problem well stated is a problem half solved !
Currently in davesss's garage:
2002 Laguna Sports Tourer 1.8 Dynamique Moondust VF1KGOB, Fiat Siecento Micheal Schumaker, Kawasaki KLE M/Cycle and a cheap Mountain Bike.
davesss is offline   Reply With Quote Quick reply to this message
Old 2nd March 2010   #3
alwyn lloyd evans
alwyn lloyd evans is
has no status.
Junior Member
Thumbs up Re: Intermittent Starting problems - Renault Megane 1.6 (2006 Model)
Try the crankshaft sensor very common fault on renaults,when it gets hot looses magnitism so the signal becomes weak however this will not show on diagnostics as it still produces a signal, have changed loads of these on clio and megs,very easy to change,located just above flywheel you need 10mill socket to remove
AL Auto electrician
alwyn lloyd evans is offline   Reply With Quote Quick reply to this message
Old 3rd March 2010   #4
dchetty
dchetty is
has no status.
Junior Member
Threadstarter
Hi there,
I been to the Renault workshop again to get clarity on the issue. According to the service advisor, the following needs to be replaced:
1. TDC sensor
2. Camshaft sensor
3. Temperature sensor
4. ABS sensor (not related though)
Apparently they have done computer diagnostics by logging into the ECU. I asked the service advisor if the sensors can be cleaned and replaced. But he says that I need all new sensors and Renault needs to replace it. He says that the sensors have to be set/calibrated by some machines that only they can do.
N.B: They also mentioned that the battery needs to be replaced.
Can the camshaft and ABS sensors be cleaned and replaced?
Donovan.
Old 3rd March 2010   #5
roby37
roby37 is
has no status.
Diamond member
Nominated 1 Time in 1 Post
Well , the probability of:-
1. TDC and loom
3. Map sensor
4. Temp sensor
all developing faults in a short time frame must rank alongside the chance of winning the lottery! Which temperature sensor? Air or coolant?
What to do ? Take the advice above! Change nothing clean the TDC, check the resistance of the air and coolant temperature sensors, check the crank sensor for continuity, the map sensor seems to have been excused. Again above, the crank sensor seems to be the favourite as a first replacement.
Addition. There is some confusion above including my post the tdc and the crank sensor are the same thing. the cam sensor is the second sensor and tends not to be so troublesome.
Currently in roby37's garage:
2005 Grand Scenic 1.5dCi
roby37 is offline   Reply With Quote Quick reply to this message
Reply
Tags
2006, intermittent, megane, model, problems, renault, starting
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
