Renault Forums :: Independent Renault forum
Notices
Engines Engine/transmission and other oily matters
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... RenaultForums store
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
...   Clio FAQ
...   Espace FAQ
...   Laguna FAQ
...   Oil FAQ
... Garage list
... Glossary
... View our rules
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... vBulletinImg
... Data
... Who drives what?
... Who supports who?
... Ads
Failed M.O.T emissions
Engines
Reply
Thread Tools Search this Thread Display Modes
Old 3rd March 2010   #1
froggy10
froggy10 is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Hi guys .............. and gals. This is my first post
My Lag failed it's MOT emissions tests. Garage says it could be due to cat or O2 sensor or both. I don't really want to pay extra for a diagnostics test if I can get away with it. I have posted the results. If any of you guys could throw some light on the matter it would be much appreciated.
Idle
CO 0.11% PASS
Fast idle
CO 0.66% FAIL
HC 68ppm PASS
^ 1.001 PASS
2nd Fast idle
CO 0.56% FAIL
HC 59ppm PASS
^ 0.998 PASS
Thanks.
Currently in froggy10's garage:
1999 laguna 2.0 16v
froggy10 is offline   Reply With Quote
5 Lastest Threads by froggy10
Failed M.O.T emissions Engines Lagdti 5 285 3rd March 2010 12:05 PM
Old 3rd March 2010   #2
roby37
roby37 is
has no status.
Diamond member
Re: Failed M.O.T emissions
Well it ain't far out! Does it have 2 sensors, before and after the cat? Is the air filter clean, the engine oil level OK (not too high) and the oil not too old?
Probability is the upstream O2 sensor failing. It can be tested for voltage output which should switch between 0.2V and 0.8V, if producing 0.6V it is on the way out.
Ultimately if it is trial and error the O2 sensor is a lot cheaper than the cat and a new sensor would not be damaged by a faulty cat.
Add.
An O2 sensor would cost about the same as a diagnostics check.
Currently in roby37's garage:
2005 Grand Scenic 1.5dCi
roby37 is offline   Reply With Quote
Old 3rd March 2010   #3
froggy10
froggy10 is
has no status.
Junior Member
Threadstarter
Not sure if it as one or two 02 sensors. The oil was 60c when tested. I bought the car a year ago and it should have been serviced then, but I'm rather trusting and didn't bother to physically check. It has only done 5000 miles of mostly town driving since I've had it. Do you think a change of filter ,oil ,and plugs could get it past the emissions test. As you say, it is not that far out.
1999 laguna 2.0 16v
Old 3rd March 2010   #4
roby37
roby37 is
has no status.
Diamond member
"Do you think a change of filter ,oil ,and plugs could get it past the emissions test."
In all honesty no! You might check the plugs but if one/more was misfiring the CO and HC would be higher.
The air filter would be worth a look but it would need to be very dirty as a choked filter is, within limits, compensated for by the O2 sensor, if it is working properly. Removing the air filter completely for the test might help in a marginal case. The within spec CO at idle and not at fast idle rather suggests a possible dirty filter.
The most likely culprit is a sluggish(failing) O2 sensor, had it failed completely the CO would be much(6%-9%) higher.
Old 3rd March 2010   #5
light47
light47 is
has no status.
Diamond member
light47's Avatar
wouldnt of thourght it was a problem with the cat you usually would be aware if the cat goes a bad eggy smell, but the plugs and air filter should help but still not a gurantee tough one to call really
Currently in light47's garage:
2005 Renualt clio 1.2 16v,
light47 is offline   Reply With Quote
Reply
Tags
emissions, failed, mot
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright � 2005-2009 RenaultForums
