Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Ask the Experts » Bodywork
Notices
Bodywork Paint care, corrossion, body kits, spoilers, skirts etc.
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... RenaultForums store
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
...   Clio FAQ
...   Espace FAQ
...   Laguna FAQ
...   Oil FAQ
... Garage list
... Glossary
... View our rules
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... vBulletinImg
... Data
... Who drives what?
... Who supports who?
... Ads
Squeeky Window Wipers & more
Bodywork
Reply
Thread Tools Search this Thread Display Modes
Old 3rd March 2010   #1
rafhelp
rafhelp is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
My wipers have started to make squeky noise when i use them. Only the right side one on front window. It looks like it is alos now leaving marks on the screen.
Is it just the blade that needs changing or the entire wiper need 'realigning' or changing?
The other thing is I have noticed that in my Megane 1.6 I have never ever topped up the water. IN other cars I have had I have had to periodically top up the water tank (for the radiator) but for this car the water level never seems to go down, why is this, is it normal. I dont drive that much is that why?
rafhelp is offline   Reply With Quote
5 Lastest Threads by rafhelp
car stereo gps` In-car entertainment ziik 1 281 25th June 2010 04:34 PM
Megane prob Engines bobbydog 1 84 10th May 2010 07:58 PM
Car not starting Engines rafhelp 4 252 3rd May 2010 09:48 PM
Old 3rd March 2010   #2
light47
light47 is
has no status.
Diamond member
light47's Avatar
Re: Squeeky Window Wipers & more
have you checked you blades for any splits??? but it probably worth whil changing the blade as they only cost a couple of quid from wilkinson, and they last well:D
as for the water levels not too shure why this would be the case of not using this much and the water level is going down dont seem to make much sense i would defanate get this looked over for any possible signs of leakage!! hope this helps!!!
Currently in light47's garage:
2005 Renualt clio 1.2 16v,
light47 is offline   Reply With Quote
Old 3rd March 2010   #3
madnoel10
madnoel10 is
has no status.
Platinum member
Nominated TOTW/F/M Award(s): 4
A new rubber wiper insert may cure the wiper problem - should cost around a couple of quid.
Ideally engines should not use any coolant so don't be concerned - as long as you check it regularly.
Currently in madnoel10's garage:
1994 Clio diesel and a Honda Civic 1.4l
madnoel10 is offline   Reply With Quote
Old 4th March 2010   #4
saabguy
saabguy is
fed up with things going wrong on his Lag.
Diamond member
saabguy's Avatar
My Mood:
Nominated 1 Time in 1 Post
Nominated TOTW/F/M Award(s): 3
If its leaving marks on the screen then it needs replacing, a good clean of the windscreen can also allow the wiper blade to run smoother.
Currently in saabguy's garage:
2001 Laguna II 1.6 16v Expression
saabguy is offline   Reply With Quote
Old 5th April 2010   #5
rafhelp
rafhelp is
has no status.
Junior Member
Threadstarter
i had to reslot the rubber blade into the housing
Reply
Tags
squeeky, window, wipers
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright � 2005-2009 RenaultForums
