Hi Folks,
My Scenic II, Handbrake applies when ignition is switched off, Disengages when moving off, Can be applied with ignition on/engine running by pulling small lever on dash, Can be disengaged ignition on/ engine running by pulling lever & pressing red button on lever, Can be disengaged by card in reader slot holding lever out & pressing red button twice ignition can then be switced off & handbrake will be deactivated with car in gear or wheels chocked i.e if car will be left standing for long periods or as handbook states chance of freezing in winter, If no power is available i.e flat battery tab in boot to disengage handbrake then visit to workshop to reset handbrake, My wife & I both easily adapted to the operation despite prior to purchase some road testers saying it was difficult, Only problem I have found is now when leaving a vehicle with a conventional handbrake I can forget to put it on luckily I always leave a car in gear .
Ottoman
Currently in ottoman's garage: Drives & Drives & Drives also Supports Many Good Causes
