The light is showing that the there is a fault in the engine management system somewhere.It could be anyone of hundreds of different problems to be honest,an
ECU code read at a good independant garage should narrow things down.You'll need to find someone with the early type Renault connector and software though as I'm pretty sure your car doesn't have the standard 16 pin connection as it's too early.
Does the car drive OK?.If it hesitates at all then the favorite thing to check would be the vaccum hose between the inlet manifold and the
MAP sensor on the bulkhead for splits/holes.
