Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Ask the Experts » Wheels & tyres
Notices
Wheels & tyres Wheels, tyres, brakes, suspension etc.
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... RenaultForums store
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
...   Clio FAQ
...   Espace FAQ
...   Laguna FAQ
...   Oil FAQ
... Garage list
... Glossary
... View our rules
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... vBulletinImg
... Data
... Who drives what?
... Who supports who?
... Ads
Laguna Rear Brake binding.
Wheels & tyres
Reply
Thread Tools Search this Thread Display Modes
Old 7th March 2010   #1
CarBug
CarBug is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
I have a Laguna 2003 mark II 1.9D
I have replaced the rear pads but the rear offside caliper is not releasing the brake properly although I have bleed the system and correctly adjusted the handbrake, ie the brake cable is not taught when handbrak is released. The brake caliper has been cleaned and is free to move.
CarBug is offline   Reply With Quote
5 Lastest Threads by CarBug
Laguna 2 DCI 1.9 Power Loss Engines scatz 2 287 22nd May 2010 02:12 PM
Laguna 1.9DCI Loosing Engine Oil Engines CarBug 6 347 12th May 2010 07:52 AM
Laguna Oil Indicator flashes -------- Engines CarBug 0 233 19th March 2010 06:03 PM
Laguna Rear Brake binding. Wheels & tyres Vickery64 4 356 7th March 2010 11:19 PM
Old 9th March 2010   #2
CarBug
CarBug is
has no status.
Junior Member
Threadstarter
Re: Laguna Rear Brake binding.
I think its the piston sticking on the caliper, ordered another, will see how it goes. This disc was excesivley worn too and failed on the MOT, replaced this and the rear pads (Both wheels). think maybe the faulty caliper has been faulty for a while.
Old 9th March 2010   #3
Lagdti
Lagdti is
n't his real name
_________________________
Lagdti's Avatar
My Mood:
Nominated TOTW/F/M Award(s): 13
Hello and welcome to the forum.
Rear calipers are quite a common problem unfortunately,but just make sure that the clips on the backs of the pads are fitted in the grove on the piston before replacing the caliper though,they can be a pain to fit correctly and if they aren't it can cause the brake to bind.
Currently in Lagdti's garage:
2000 Renault Espace 2.0 RTX + 1997 Renault Megane 1.6E
Lagdti is offline   Reply With Quote
Old 10th March 2010   #4
Laguna01
Laguna01 is
has no status.
Member
I also have problems with a sticky rear offside brake..and it's caused by the handbrake cam not releasing after taking the handbrake off..usually cured by using spray lubricant and working it back and forth a few times until it loosens up
Currently in Laguna01's garage:
Laguna II 1.8 tourer
Laguna01 is offline   Reply With Quote
Old 10th March 2010   #5
Vickery64
Vickery64 is
has no status.
Diamond member
I had a similar problem. It was caused by the pads not being clipped onto the calliper properly. They can be a bit fiddely to get the springs on the pad to engage as the rubber boot can get in the way.
Worth double checking maybe
Currently in Vickery64's garage:
2001 Laguna II V6 24 valve
Vickery64 is offline   Reply With Quote
Reply
Tags
binding, brake, laguna, rear
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright � 2005-2009 RenaultForums
