Re: CLIO 1.5 DCI Pre-heater housing leak
Scatz, thank you for your reply. Unfortunately I wasn't there and all they did was write down that it needed this part. It's in the engine bay and they said only on diesels - looking at the net, I couldn't find much, only that it appears to be something that uses the hot "coolant" to pre-heat the diesel fuel.
They tested the system by pressurising it and found the leak - they then changed a clip on it (I presume Jubilee clip) and thought they'd fixed it, but after running it for 20mins it started leaking again.
They topped it to max and after a 20mile trip down an A road it was just below min. I'm puzzeled as to what it wrong - could it need a new gasket, new hose, clip or it it cracked, hence why I'd like to get to it. I've looked for the new clip, but can't find it.
Thank you,
