Hi there,
I was wondering if anyone could offer advice on a slight problem that has developed on my 2004 Grand scenic 1.9 DCI. It has been fitted with a brand new engine 30K ago and upto now has been faultless, using no
oil. It had it's last
oil change approx 5k ago, using the recommended Elf fully synthetic
oil. I noticed about 200 miles ago that the
oil level meter had dropped 2 bars on the gauge and this week have noticed a faint smell of
oil when parking up after a journey. I have had a look under the bonnet and there is a lot of
oil on the front face of the engine, which seems to be coming from where the filler neck assembly goes into the block. This 'filler neck' assembly seems very loose in the block hole and can easily be lifted up 1/2".
My thoughts are that either the 'looseness' of the filler neck into the block is letting
oil seep out through capillary action OR that there is a blockage in the vent system which is causing the
oil to leak out, maybe a blocked
EGR or something.
Any help or advise would be much appreciated.
