Re: Leaking injector Help
usually those injectors are stuck in the head. before you try to remove the injector . clean the injector area then pour brake fluid generously and leave it for 12 hours.
the you may try to remove the injector. don't forget to clean out the brake fluid before removing the injector.
after that if you're still cant remove it you will have to remove the cylinder head to extract the injector .GOOD LUCK !!!
Currently in mechanic's garage: Megane II DCi 1.5, Symbol 1.6 16v ,Nissan Sunny
