Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Ask the Experts » Wheels & tyres
Notices
Wheels & tyres Wheels, tyres, brakes, suspension etc.
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... RenaultForums store
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
...   Clio FAQ
...   Espace FAQ
...   Laguna FAQ
...   Oil FAQ
... Garage list
... Glossary
... View our rules
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... vBulletinImg
... Data
... Who drives what?
... Who supports who?
... Ads
CV Joint = ABS Fault?
Wheels & tyres
Reply
Thread Tools Search this Thread Display Modes
Old 13th March 2010   #1
goldsabre
goldsabre is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
I had my ABS light come on the other day and the computer voice telling me.. "automatic braking system is faulty, please consult Renault dealer bla bla bla..." I searched the forums and found some very useful info on how to check the connections etc but to no avail. I then discovered a thread on testing the ABS sensor with a digital multi meter. When I got to the front drivers side wheel I noticed a load of grease around the rubber gator and splattered on the inside of the wheel which I never noticed before!!! Could this be linked to the ABS fault?
Currently in goldsabre's garage:
2002 Renault Laguna 1.8 Privilege
goldsabre is offline   Reply With Quote
5 Lastest Threads by goldsabre
CV Joint = ABS Fault? Wheels & tyres goldsabre 9 595 13th March 2010 11:36 AM
ABS Sensor Fault Wheels & tyres goldsabre 0 162 21st February 2010 10:27 AM
Old 13th March 2010   #2
madnoel10
madnoel10 is
has no status.
Platinum member
Nominated TOTW/F/M Award(s): 4
Re: CV Joint = ABS Fault?
Most probably. The wheel bearing has a magnetic ring which spins past the ABS sensor - if the magnetic field is blocked then no signal is generated. If you connect a multimeter to the sensor and spin the whell you should get a pulsed voltage read out. A clean up and a new boot clip and a repack of grease may solve the problem.
Currently in madnoel10's garage:
1994 Clio diesel and a Honda Civic 1.4l
madnoel10 is offline   Reply With Quote
Old 13th March 2010   #3
Phaeton
Phaeton is
has no status.
Diamond member
Phaeton's Avatar
Quote:
Sorry bit of a thread hi-jack, I didn't think you could test ABS pickup's with a Multi-Meter I thought they produced a sine-wave which could only be detected by a 'proper' machine.
Alan...
Currently in Phaeton's garage:
'52 Laguna II Sports Estate 1.9DCi | '93 Mr2 Turbo | Funbuggies Freestyle 1275
Phaeton is offline   Reply With Quote
Old 13th March 2010   #4
madnoel10
madnoel10 is
has no status.
Platinum member
The effect of the magnet passing the coil of the ABS sensor should produce a small fluctuating voltage - down in the millivolt range. It a rough and ready check.
See link below for some info.,
http://www.topbuzz.co.uk/maintenance...esting_abs.htm
Old 14th March 2010   #5
goldsabre
goldsabre is
has no status.
Junior Member
Threadstarter
Smile Re: CV Joint = ABS Fault?
Cheers for that. I did at first suspect that a wire had been pulled off during a recent service as the light came on about 50 yards down the road from the service centre!!! I am taking it to a Bosch service centre tomorrow to have a diagnostic and get them to have a look at the cv boot. Hope it's not too expensive!!!
I'll let you know the outcome...
Reply
Tags
abs, fault, joint
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright � 2005-2009 RenaultForums
