Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Ask the Experts » Wheels & tyres
Notices
Wheels & tyres Wheels, tyres, brakes, suspension etc.
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... RenaultForums store
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
...   Clio FAQ
...   Espace FAQ
...   Laguna FAQ
...   Oil FAQ
... Garage list
... Glossary
... View our rules
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... vBulletinImg
... Data
... Who drives what?
... Who supports who?
... Ads
Laguna II front lower ball joint not coming out :(
Wheels & tyres
Reply
Thread Tools Search this Thread Display Modes
Old 13th March 2010   #1
tbeith
tbeith is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
I am replacing the drivers side front lower arm and have removed the 2 bolts connecting it to the subframe but I can not remove the lower ball joint. The nut is off but the ball joint will not come out.
I have tried to hit it out with a hammer etc and it is not budging at all.
Any advice as to what I should do nexT!?!?!
Tom
Currently in tbeith's garage:
2002 Renault Laguna Sport Tourer 2.0 IDE
tbeith is offline   Reply With Quote
5 Lastest Threads by tbeith
Laguna II front lower ball joint not coming out :( Wheels & tyres tazdevil 17 871 13th March 2010 05:04 PM
Old 13th March 2010   #2
madnoel10
madnoel10 is
has no status.
Platinum member
Nominated TOTW/F/M Award(s): 4
Re: Laguna II front lower ball joint not coming out :(
The lower ball-joint is a taper fit to the hub carrier and you will need a ball-joint separator to release it. They can be darned tight.
Currently in madnoel10's garage:
1994 Clio diesel and a Honda Civic 1.4l
madnoel10 is offline   Reply With Quote
Old 13th March 2010   #3
Phaeton
Phaeton is
has no status.
Diamond member
Phaeton's Avatar
An old trick that may work but needs 4 hands really, hold a lump hammer tight against hub carrier at one side. Then with another hit the other side sometimes the shock will loosen it.
Another way is to put the arm back onto the subframe, get a trolley jack under the disc so it's just taking the weight. Get a long bar 4-6 feet & pass over the bottom arm & wedge it under the car then force the bar down.
Please note, these are rough ar$e ways of doing things & I take no responsibility for damage to you, your property or your loved ones, they have however been very successful in the past.
That said a proper balljoint splitter is what you really need, there are 3 in my garage if you live near Worksop & want to borrow one.
Alan...
Edit:- Just to say if you try the bar method, put the nut back on the balljoint a couple of turns so the arm doesn't drop all the way, meaning the pipe/bar will have a mind of it's own.
Currently in Phaeton's garage:
'52 Laguna II Sports Estate 1.9DCi | '93 Mr2 Turbo | Funbuggies Freestyle 1275
Phaeton is offline   Reply With Quote
Old 13th March 2010   #4
madnoel10
madnoel10 is
has no status.
Platinum member
Alan...
Strangely enough I have never owned a ball-joint splitter. As yet the rough ar$ed hammer method and a 5 foot crow bar has served we well although you do need to be realy accurate with your hammer blows. I have seen this method work where splitters have failed.
Oh the joys of the american shifting spanner
Old 13th March 2010   #5
tbeith
tbeith is
has no status.
Junior Member
Threadstarter
I have tried a ball joint speperator but it just kept slipping off, all the rubber around the ball joint has perished and most of it has come off so I am not sure if this is why or if it just because the ball joint tool is a cheap one from ebay!?
I will try the lump hammer method tomorrow, unforunately I have grinded most of the arm off because it was getting in the way of my 'beating the hell out of the ball joint' activities.....
grrrrr
Reply
Tags
ball, coming, joint, laguna, lower
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright � 2005-2009 RenaultForums
