Renault Forums :: Independent Renault forum
Notices
Engines Engine/transmission and other oily matters
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... RenaultForums store
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
...   Clio FAQ
...   Espace FAQ
...   Laguna FAQ
...   Oil FAQ
... Garage list
... Glossary
... View our rules
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... vBulletinImg
... Data
... Who drives what?
... Who supports who?
... Ads
Idle Air Control Valve - Stepper Motor 1.6VVT 2004
Engines
Reply
Thread Tools Search this Thread Display Modes
Old 14th March 2010   #1
lotussam
lotussam is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Hi, could anyone advise if there is an Idle air control valve or stepper motor on a 1.6 VVT Scenic engine 2004? When I start the car from cold I have to give it some throttle so it keeps running. With steady pressure on the throttle the revs rise and fall all by themsleves. After a while (1-2 mins) it all settles down. Starting from hot it is fine. Friend mentioned the above valve but can't find any details on the 2004 1.6 VVT. Any help or ideas on how to fix greatly received. Thanks
lotussam is offline   Reply With Quote
5 Lastest Threads by lotussam
Rattle on Start Up - Scenic 2004 Engines jaypayne 5 511 24th May 2010 07:43 AM
Idle Air Control Valve - Stepper Motor 1.6VVT 2004 Engines lotussam 3 528 14th March 2010 03:35 PM
Scenic 2 1.6 VVT wont start!!! Engines mechanic 3 179 5th March 2010 06:05 PM
Poor Starting Scenic II 1.6 Engines lotussam 3 117 1st March 2010 03:56 PM
Old 14th March 2010   #2
Haree
Haree is
has no status.
Diamond member
Send a message via MSN to Haree
Re: Idle Air Control Valve - Stepper Motor 1.6VVT 2004
Hello,
I don't know if there is a stepper motor on the 1.6 16v VVT K4M engine but I would imagine there would be an idle control valve. You mention you have to give it some revs to start it from cold. Do you get a rattle like noise on start up.
Harry.
Currently in Haree's garage:
I don't have a garage just a driveway. The Modus 1.6 16v VVT Dynamique Auto is my Grandparents car which I also drive.
Haree is offline   Reply With Quote
Old 14th March 2010   #3
madnoel10
madnoel10 is
has no status.
Platinum member
Nominated TOTW/F/M Award(s): 4
It could possibly be a faulty engine coolant sensor whereby the ECU thinks the engine is always hot and not add additional fuel or extra rpm when cold.
Currently in madnoel10's garage:
1994 Clio diesel and a Honda Civic 1.4l
madnoel10 is offline   Reply With Quote
Old 15th March 2010   #4
lotussam
lotussam is
has no status.
Junior Member
Threadstarter
Thanks for your suggestions. It doesn't make a rattling noise when it starts. I will look at the engine coolant sesnor. Thanks for your ideas.
Reply
Tags
16vvt, 2004, air, control, idle, motor, stepper, valve
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright � 2005-2009 RenaultForums
