Scenic 1.9 dci Turbo Blown - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 15th March 2010   #1
Welsh123
Welsh123 is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
I bought a Renault Scenic 1.9dci about 4 months ago from a used car dealer. It is a 2006 model. Yesterday on the motorway we heard a strange whistling noise for some time, then the electrical fault button lit up. We pulled over, the button went off, so we continued driving, but about 10 minutes later the gearbox seemed to disengage (couldn't switch gear, had to stall car), thick smoke began trailing out the back of the car and there were actual sparks & fire which I'm told was from oil going down the exhaust.
There was a fire engine at us in less than 3 minutes and they spent about half hour hosing the car down underneath with thick steam coming off it and said under no circumstances could we try to restart the car. We were put in a very dangerous situation, we had animals in the back which were extremely distressed by the amount of heat and smoke and the fire truck as well as having to stand on the side of a motorway in a dangerous position in the freezing cold for two hours waiting for a tow truck on a sunday. My wife was extremely scared & upset and my animals need antibiotic eye drops for the smoke damage and we are just very grateful we got off the motorway safely and the fire brigade were so prompt.
We had to get it towed home (150 miles!) and the local garage says that the turbo has blown (we also need to replace the catalytic converter and exhaust due to the burning oil that created the sparks/smoke I'm told) and they are looking for quotes but I've been told it could potentially be £3000+
I have no warranty from the dealer - this was our first car and in hindsight perhaps we did not get the best one as it has 160,000 miles on the clock which I believe means Renault will have nothing to do with it as it comes under wear and tear, is that right? I strongly believe this problem if a known one, could put lives at risk which should never come under any wear and tear descriptor!
It has been frequently serviced in accordance with the mileage. I know this is a lot of mileage but we were told because it had a very good service history that there would be no problems, and I guess we had a good salesman. It was owned by a company and was used by sales reps so it does have a full and on time service history.
Is there anything we can do in regards to this problem? It seems now after searching that it is a known fault, but it seems an extremely dangerous fault, not only to ourselves but to all passing motorists as view was actually obscured for some drivers by the amount of smoke or do we have to chalk it down to us being stupid to buy a car with such a high mileage and no warranty.
Our first car so we are absolutely gutted and totally confused to have such a massive problem happen. The problem is going to cost almost as much to fix as the car cost to buy so it may be a scrappage job now but I know it's our own fault as we bought such a high mileage car and no warranty.
Is there anyone we can write to, to complain about this problem and how dangerous it potentially could be or is it pointless and we just have to suck up the cost or scrappage and learn from it.
Welsh123 is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by Welsh123
Scenic 1.9 dci Turbo Blown Engines maccauk11 7 10696 15th March 2010 06:34 PM
Sponsored Links
Advertisement
Old 16th March 2010   #2
Phonebox
Phonebox is
has no status.
Diamond member
Smile Re: Scenic 1.9 dci Turbo Blown
Hi, what an awful experience, you have my sympathy!
Turbo failure is indeed a common problem with the dci engine (I've had it happen twice)and in fact many other turbo diesels, but it would seem that when the Renault one fails it does so in a very dramatic fashion, often ruining the engine. I've personally never heard of it resulting in a fire but I guess it can happen.
If I read your post correctly it seems you managed to get the engine stalled and the garage isn't talking about engine damage so it should be ok.
However £3000 sounds way too much for what they're talking about replacing-I presume this is a Renault main dealer? If so I'd suggest you go to a good local independent garage. Ask them to source a good reconditioned turbo (or do so yourself -expect to pay around £350 for one on Ebay for example or googling dci turbo will bring up plenty of recon companies), an aftermarket cat if they reckon it's needed and possibly an intercooler. A good garage will know what they're doing but it's vital that as well as cleaning/replacing the intercooler all the turbo pipework is thoroughly cleaned to remove all traces of the shattered vanes from the old turbo. Going this way, you should be able to get back on the road for about £1000-still a lot of money but much less than £3000!
As to who you could complain to, Renault Customer Services would be your main option. Personally though I don't think you'll get much satisfaction from them. It would be worth checking the cars' service history to see if it's had a turbo replaced before. At 160k I'd be amazed if it hadn't as 90k seems to be the average lifespan for a dci turbocharger, and if it has and it was fitted and regularly serviced since by the main dealer, you might squeeze a goodwill contribution out of RCS. But they'll only do this if the work is done by their dealer which means you'll pay more even with their contribution than you would at an indie.
As to whether you fix or scrap, personally at £1k I'd fix it. The dci engine is basically pretty robust, many see service in taxis and vans and go on to mileages well over 250k. Regular servicing and in particular oil changes with fully synthetic oil are the key here. The fact yours has a full service history is reassuring. In most other respects the Scenic should be as reliable as the majority of its' peers.
Good luck and I hope you get it sorted!
Currently in Phonebox's garage:
1996 2.0 RT Family Estate and 2001 Laguna II 1.9Dci Privilege Sports Tourer.
Phonebox is offline   Reply With Quote Quick reply to this message
Old 14th June 2011   #3
sheffandy
sheffandy is
has no status.
Junior Member
We this weekend had a similar problem.
We bought a Scenic II 1.5 Dci Expression(53 plate) from a guy in Leeds. Just 4 days later on the M18 the turbo blew at 70 MPH and was lucky not to get killed in the process.
Had to be towed by AA back home
My mechanic has quoted £1000 for a new turbo & cat converter.
Told him not to bother as this is my last Renault.
After quite a bit of googling I find this is a common fault! If this had been my pregnant wife with our 3 year old in the back I shudder to think what would have happened.
So, if you are reading this forum and in the process of deciding whether or not to buy a Renault, STEER CLEAR! I will go back to my trusty Xsara Picasso after choosing a Scenic nearly cost my son and unborn child their father.
Currently in sheffandy's garage:
Non Runner Scenic II (For Sale offers?) Sheffield area.
sheffandy is offline   Reply With Quote Quick reply to this message
Old 14th June 2011   #4
Azurael
Azurael is
<|---Knee--<<<
Platinum member
Azurael's Avatar
Nominated 0 Times in 2 Posts
It most certainly isn't a common fault on the 1.5 dCi, or at least not any more than any other manufacturers turbodiesel engines. But then, I suspect you have a 1.9 dCi as its a 53 plate?
__________________
All murderers are punished unless they kill in large numbers and to the sound of trumpets. - Voltaire
Currently in Azurael's garage:
TEB64 (Cosmic Grey) 2001 'Y' Laguna II 1.8 16v Privilege Tourer (KG0B F4P-770)/TED44 (Odyssey Blue) 2001 'Y' Laguna II 1.8 16v 'Expressionale' Hatch (BG0B F4P-770)
Azurael is offline   Reply With Quote Quick reply to this message
Old 15th June 2011   #5
sheffandy
sheffandy is
has no status.
Junior Member
Quote:
Nope it's definatley a 1.5 Dci.
Try doing a google search for 'scenic blown turbo', and a quite a few forums cover exactly what happened to me.
One poor woman had her 2 kids in the back when it happened.
Once was enough for me.
Reply
Tags
blown, dci, scenic, turbo
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
