Clio Heater Control Panel removal - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Ask the Experts » Heating & cooling
Notices
Heating & cooling A place to discuss heating, air-con etc.
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Heating & cooling
Reply
Thread Tools Display Modes
Old 15th March 2010   #1
welshnutteruk
welshnutteruk is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Hi the heater control panel has gone, I have found a replacement does anyone know how to remove it
I had a quick look there are two screws on front and looks like i will have to remove console around gearstick is there anything else i will need to remove to get the control panel out
regards chris
Currently in welshnutteruk's garage:
clio sport
welshnutteruk is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by welshnutteruk
Clio Heater Control Panel removal Heating & cooling TristenNorman 6 11688 15th March 2010 09:00 PM
Sponsored Links
Advertisement
Old 15th March 2010   #2
owenstringer
owenstringer is
Taking my private pilots liscence
Diamond member
Re: Clio Heater Control Panel removal
if this is the clio mk 2 phase 1 then you got it in one, gear stick consol off then 2 screws on the heater panel, owen
Currently in owenstringer's garage:
Megane 2 1.6 dynamique 2004
owenstringer is offline   Reply With Quote Quick reply to this message
Old 20th March 2010   #3
welshnutteruk
welshnutteruk is
has no status.
Junior Member
Threadstarter
Hi all ok changed the control panel but the heater blower still doesnt work check fuse, what else could be wrong it was working on and off before on speed 3 & 4 then only on 4 and then nowt so changed the switch control panel
rehards chris
clio sport
Old 20th March 2010   #4
owenstringer
owenstringer is
Diamond member
its never usually the control panel, its most probably the resister pack, what clio do you have i might be able to give you a better idea, owen
Old 21st March 2010   #5
welshnutteruk
welshnutteruk is
has no status.
Junior Member
Threadstarter
Hi its a W reg clio alize 1.6
my mate was told by a garage that it was the control panel and that he cleaned the insides and it worked for about a year, and that it would need changing as its worn (fitted a new control switch and still no luck) me think the bloke didnt know what he was on about so ok its not the switch so what else can it be
regards chris
clio sport
Reply
Tags
clio, control, heater, panel, removal
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
