Scenic II Drivers side Electric Window has a mind of its own - Intermittent fault
Good Morning all.
My 53 plate Scenic is playing up. The driver's side electric window has developed a mind of its own.
On Saturday night I dead locked the car (Double pressed the lock button) and the Drivers side window kicked into life and wound it self open.
Spent the best part of 2 hour trying to get the damn thing shut in the dark - tried turning engine on and off, opening a closing other windows, checked all the fuses in the glove box, connecting the battery and reconnecting but no life what so ever.
Gave in and locked the car to go and get something to cover the window up with until the morning and the window rose about an inch. At this point I tried turning the engine on again and the button then worked so was able to close up the window.
Since then the fault as been intermittent. Sometime the controls will work and other times it just dies again.
I have since deadlocked the car numerous times and sometimes the window stays shut and other times it winds open.
I don't think its water as we've had no rain and checking inside the door under the trim the interior of the door appears dry, and likewise the loom into the control on the door, and on the motor appear in good order and all wires appear tight into the looms.
Also I have noticed that occasionally when the controls are working when nothing is being pressed there is a noise coming from the window motor as if the motor is trying to open or close the window.
I though it may be the switch that is faulty, but that doesn't explain why the window would wind open occasionally when the deadlock is used.
Searching through the forums I can't see anyone with a similar issue, The regulator clip is intact.
Any ideas or suggestions on what else I could try before it goes to the dealer's would be really appreciated
Thanks you in advance for any suggestions
Currently in altheman2004's garage: 2003 Renault Scenic II 1.9DCI Privilege
