Renault Forums :: Independent Renault forum
Notices
Engines Engine/transmission and other oily matters
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... RenaultForums store
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
...   Clio FAQ
...   Espace FAQ
...   Laguna FAQ
...   Oil FAQ
... Garage list
... Glossary
... View our rules
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... vBulletinImg
... Data
... Who drives what?
... Who supports who?
... Ads
!998 Megane dti Erratic idle
Engines
Reply
Thread Tools Search this Thread Display Modes
Old 16th March 2010   #1
trustmax
trustmax is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Red face !998 Megane dti Erratic idle
Hello.
Recently acquired a almost mint example with lots of well maintained miles (161000) and one of the first with this engine, March 1998. This is fitted with the F9q dti 1.9 diesel engine. It came with a "slightly sticky accelerator cable, needs a bit of wd40 mate".
It is not dangerous to drive and only occurs occasionally with the revs' sticking for about 5- 15 seconds before coming down to 800 approx'.
Armed with a can of said lubricant, i tried this remedy, but have found that there is no such cable. At the end of the acc' pedal there's a cylinder with an electronic connection. No cable. At the pump there is only wired connector, which is clearly the other end of the acc' pedal cylinder cable.
Clearly this a 'drive by wire' connection and no amount of lubrication will work. Any idea about what this connector / sensor is called?
Can it be replaced , and if so and what end?
Pedal or pump.
Alternatively could the EGR valve be the culprit?
No warning lights or other driveability problems.
Currently in trustmax's garage:
1998 megane rt dti hatchback
trustmax is offline   Reply With Quote
5 Lastest Threads by trustmax
!998 Megane dti Erratic idle Engines trustmax 0 152 16th March 2010 11:14 AM
Reply
Tags
998, dti, erratic, idle, megane
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright � 2005-2009 RenaultForums
