Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... RenaultForums store
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
...   Clio FAQ
...   Espace FAQ
...   Laguna FAQ
...   Oil FAQ
... Garage list
... Glossary
... View our rules
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... vBulletinImg
... Data
... Who drives what?
... Who supports who?
... Ads
TDC sensor siemens to old Bosch type
Electronics
Reply
Thread Tools Search this Thread Display Modes
Old 16th March 2010   #1
keef666
keef666 is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Angry TDC sensor siemens to old Bosch type
I have just got my new Siemens TDC sensor for my Renault Scenic 1.6 16v car, the new Siemens (yellow & pink) has different coloured wires to the loom that feeds the old type Bosch (green & brown). Which wire goes to which colour
Thanx in advance.
keef666 is offline   Reply With Quote
5 Lastest Threads by keef666
TDC sensor siemens to old Bosch type Electronics keef666 5 340 16th March 2010 11:39 AM
Hello all Welcome to RenaultForums hondo 1 73 14th March 2010 10:31 AM
Old 16th March 2010   #2
keef666
keef666 is
has no status.
Junior Member
Threadstarter
Re: TDC sensor siemens to old Bosch type
I truly believed someone might know but alas still no reply and 36 views.
Old 16th March 2010   #3
keef666
keef666 is
has no status.
Junior Member
Threadstarter
lol so much for 'ask the experts' heading.
Old 18th March 2010   #4
keef666
keef666 is
has no status.
Junior Member
Threadstarter
I have now fitted the new siemens TDC sensor to the car (Renault Scenic 1.6 16v 'W' reg Auto) it is very fiddly to get the sensor into the flywheel housing because the loom carrier gets in the way.
The other difficulty was the new TDC sensor (siemens blue one) the old black one had 2 brass boss's which fit inside the flywheel bell housing recess's.
I had to remove the brass boss's using grips to remove them from the bracket, I then inserted the boss's into the new Siemen's sensor (the correct orientation of course) and riveted the brass boss's to the steel using a ball pane hammer.
Insert the sensor and bolt tightly.
The wiring on my old sensor was green and brown wires? I connected the pink (new sensor) to the green wire and the yellow (new sensor) to the brown wire.
Bingo sorted.
I also changed the spark plugs and it runs like a dream!
Please note:
Renault bulletin water ingression is a known fault on old style pencil coils- smear with denoso grease (from Renault garage) around the bottom shoulder on the pencil coil.
The pencil coils have been update because of this issue and can be recognized by a rectangular cut-out on the shaft of the new style pencil coil. (you probably know this anyway but hey).
Old 28th July 2010   #5
seckford123
seckford123 is
has no status.
Junior Member
seckford123's Avatar
Great post.
I would like to take off and clean/replace the TDC sensor on my 2001 Scenic 1.6 16v Automatic but cant find its location. Haynes says left of gearbox bellhousing engine block. Ive looked and looked but nothing resembles the pictures in the manual?
Are some models different?
Have you any photos?
Many Thanks
Simon
seckford123 is offline   Reply With Quote
Reply
Tags
bosch, sensor, siemens, tdc, type
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright � 2005-2009 RenaultForums
