Hello Everyone,
I hope someone can help. I've had my Clio about 4 years. The engine warning light has come on before, causing the car to go into limp mode. I was advised that the "
coil" needed changing and was a common fault on Clios. This was changed and it continued to run fine for several years.
Recently the problem has returned, causing the car to go into limp mode again, sometimes whilst driving, most often when going up hills?! I've taken it to a garage who have had the car for 5 weeks and are still unable to diagnose the problem due to the car not giving them a reading.
They have taken the car to be read elsewhere (Jensens?) who have given them 2 codes:
DF045 (which they have said that they have cleared)
and
CIA0F or C1A0F (or any other variations you can get from I,1,O and 0?!?!?), which they can't interpret. They're also not sure if this is even causing the problems.
They have already spent time taking off the housing of the electrics (which is apparently welded to the engine) to work on the wires, as he said that it can often cut through them. He has also changed a part due to concerns that it was letting in too much air. I've paid him for these 2 misdiagnosies already, but he's now reluctant to give me a costing for the work he's done on-top. He said he's reluctant to change the
ECU as this may not solve the problem. I'm just concerned that he's had my car for a long time and the costs are going to escalate.
Sorry to write so much but, CAN ANYONE PLEASE HELP............
Helen
