How to change cam sensor on megane 1.6 vvt 04 - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 20th March 2010   #1
taffyo0
taffyo0 is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
hi can some help ,,,need to know how to change cam sensor,,ive heard it takes 10 min and also heard it a big job like taking off manifold can some one tell me exactly how easy or hard it is,,,thanks
taffyo0 is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by taffyo0
knocking on cold startup Engines madnoel10 1 931 23rd November 2011 07:36 PM
How to change cam sensor on megane 1.6 vvt 04 Engines Sgjones 11 23247 20th March 2010 08:26 PM
Sponsored Links
Advertisement
Old 20th March 2010   #2
dcikev
dcikev is
has no status.
Member
Wink Re: How to change cam sensor on megane 1.6 vvt 04
hi, yes it's a quick job! just remove the 4th ignition coil (that's the one on the far right of the engine) it's held in place with a 10mm bolt,this will give you better access to the 10mm bolt which holds the cam sensor in place,be careful not to drop the bolt into the hole and remember to remove the rubber 'o' ring from the old sensor as the new one probably won't have one. the engine managment light should go out after a few trips!
Currently in dcikev's garage:
2004 scenic 1.9dci,2004 megane 1.6vvt
dcikev is offline   Reply With Quote Quick reply to this message
Old 20th March 2010   #3
taffyo0
taffyo0 is
has no status.
Junior Member
Threadstarter
thx,,,will give it a go tomorrow
Old 20th March 2010   #4
pesso1
pesso1 is
has no status.
Junior Member
Smile Re: How to change cam sensor on megane 1.6 vvt 04
Quote:
hi taffyo0
the sensor is located near ignition coil no' 1 (flywheel side) after the replacement you nead to reprogram the engine computer otherwise teh problem well not be solved
Currently in pesso1's garage:
kangoo 1.5 dci
pesso1 is offline   Reply With Quote Quick reply to this message
Old 21st March 2010   #5
dcikev
dcikev is
has no status.
Member
no need to reprogram the computer as the light will cancel itself out after a few trips,failliing this connect it up to a obd reader to cancel the light as i have done with mine.
The Following User Says Thank You to dcikev For This Useful Post:
Sgjones (29th June 2011)
Reply
Tags
cam, change, megane, sensor, vvt
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
