Quote:
Originally Posted by quickshaun
Hi, I've just had a new clutch fitted including slave cylinder and now the electronic fault light & glow plug light comes on every now and then. It seems to lose all power then for no apparent reason it goes off and then is fine again. Any ideas would be greatfully received. Could it be the camshaft sensor as this got damaged when removing the gearbox?
Yeh it could be ,they do suffer from that ,just had that problem with mine ,changed the air flow meter and now it's fine ,but now the throttle does'nt work when you start it up.
