Clio Ignition Switch - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Electronics
Reply
Thread Tools Display Modes
Old 6th April 2010   #1
Chris beckett
Chris beckett is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Unhappy Clio Ignition Switch
Hi, wondering if any one can advise me on this problem with ignition switch.
From last week, when I turn the ignition key from Mark 3 to Start the engine the starter motor turns over but the switch does,t move back to Mark 3 automatical, so I have to move the key back myself or the starter motor keys spinning. Also since this has happened I get an intermitent fault where either when using headlights they are on full beam, or when using the windscreen wipers when I depress the break the rear windscreen wiper works.
I have checked the Earch connections in the boot already.
Is this a broken Ignition Switch or an electrical fault connected to the Starter motor.
Gratefull for any pointers. Cheers
Currently in Chris beckett's garage:
2003 Renault Clio 1.2 16v
Chris beckett is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by Chris beckett
Losing power Engines madnoel10 1 831 24th July 2011 04:23 PM
Grinding/Rubbing noise on Clio Engines andytvcams 2 992 27th December 2010 05:00 PM
Clio 1.2 16v Toxic Fume Light stays on Engines Chris beckett 3 1915 28th October 2010 03:54 PM
Clio Ignition Switch Electronics Chris beckett 2 5446 6th April 2010 08:39 PM
Sponsored Links
Advertisement
Old 7th April 2010   #2
Hopless
Hopless is
has no status.
Diamond member
Re: Clio Ignition Switch
brocken switch, common fault.
Turn to poss 1? to be able to push in locking pin after removing T20 torx
Currently in Hopless's garage:
Mercedes pagoda W113
Hopless is offline   Reply With Quote Quick reply to this message
Old 8th April 2010   #3
Chris beckett
Chris beckett is
has no status.
Junior Member
Threadstarter
Thanks - now to find an ignition barrel from some where!
Reply
Tags
clio, ignition, ignition switch, switch, swith
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
