HELP! 1.9DCI Megane will not cold start - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 13th April 2010   #1
westie666
westie666 is
has no status.
Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Question HELP! 1.9DCI Megane will not cold start
Yesterday the 1.9DCI (F9Q with 59K miles) would not start, after trying to start with jump leads, this did not work.
A bump start got the car working to the point it got to the local garage.
FIX: New glow plugs (noticed a check injection error last week, and measured resistance and voltage last week - looked like 3 faulty glow plugs) Cost for 4 plugs and labour £75
This morning same issue.
I'm thinking injectors needing cleaned, as I am bad for running the fuel very low in the fuel tank.
This is also thinking due to a couple of hesitations a fortnight ago, but nothing for 10 days, then this. Batt reading 12.65v with no load. unknown with load.
ANY MORE IDEA'S???
Currently in westie666's garage:
Megane II Sport Tourer 1.9 dci & Citroen C4 1.6 SX 5dr Hatchback
westie666 is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by westie666
Oil for oil change Engines westie666 4 1450 20th May 2010 01:48 PM
Loosing brake fluid, but not appearing anywhere! Engines westie666 5 2399 12th May 2010 04:32 PM
Best Place to get a catch tray! Engines mord 3 1265 3rd May 2010 11:12 AM
1.9DCi (F9Q) non start Engines westie666 2 2249 15th April 2010 03:20 PM
HELP! 1.9DCI Megane will not cold start Engines westie666 1 1461 13th April 2010 10:35 AM
Sponsored Links
Advertisement
Old 20th April 2010   #2
westie666
westie666 is
has no status.
Member
Threadstarter
Re: HELP! 1.9DCI Megane will not cold start
To close this post!
Got to the bottom of the issue yesterday!
Called the AA out as the car would not Bump start (car was at mum's house so no home callout!)
Not battery, easy start does not work.
no faults on fault reader.
Checked crank speed 0 RPM.
1x Crank shaft sensor from renault (£30.81)
DONE!
No error messages...thanks to all for your help!
G
Reply
Tags
19dci, cold, megane, start
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
