Renault Scenic 2 auto gearbox problem and garage recommendation - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Ask the Experts » Transmissions
Notices
Transmissions Transmissions...
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Transmissions
Reply
Thread Tools Display Modes
Old 16th April 2010   #1
spin
spin is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Hi All. Problem with the auto gearbox in my Scenic, which I purchased about 1.5 years ago, and led me here so hope some body can help me.
My 05 2 litre Grand Scenic often get into limp home mode where the gearbox does not shift beyond second with a gearbox/electrical fault displayed on the console. If I were to switch off the engine and on again, that seems to clear the fault and I can drive normally. During normal driving, the gearbox is very hesitant to shift up and I normally use the semi auto gear shift to change.
Now, I have search the forum and it seems like a common problem just like this thread.
http://www.renaultforums.co.uk/showt...t=auto+gearbox
My questions are:
1. What exactly is the problem with gearbox? Is it the hydraulic bearing?
2. Was there ever a recall for this issue? As the warranty is long over I am guessing the repair cost for the auto box is going to be quite high.
3. I live in Glasgow and the local Renault dealer -Arnold Clark- is quite expensive and I would rather go to a cheaper independent specialist. Any recommendation is welcome.
Thanks.
spin is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to spin For This Useful Post:
pasmaur (6th August 2011)
5 Lastest Threads by spin
Renault Scenic 2 auto gearbox problem and garage... Transmissions caroleuk 14 44263 16th April 2010 05:26 PM
Sponsored Links
Advertisement
Old 16th April 2010   #2
Haree
Haree is
has no status.
Diamond member
Nominated 0 Times in 2 Posts
Re: Renault Scenic 2 auto gearbox problem and garage recommendation
Hello,
without plugging your car into a diagnostics machine I cannot say for 100% certain what is wrong with the auto gearbox but your car is fitted with I am pretty certain a 4 speed DPO torque converter autobox, although it may be a Nissan JATCO autobox. They are a more reliable box then the mk1 scenic auto boxes, but the most common failure is the EVM solonoid valves can pack up and would cause the lumpy shifting and limp mode you refer to. How much is Arnold Clark Charging. I cannot reccomend any specific garage to you, but your best bet would be to take the car to an automatic gearbox specialist someone who is a member of FATE. Go onto www.fedauto.co.uk for more info.
Harry.
Currently in Haree's garage:
I don't have a garage just a driveway. The Modus 1.6 16v VVT Dynamique Auto is my Grandparents car which I also drive.
Haree is offline   Reply With Quote Quick reply to this message
Old 19th May 2010   #3
markam1955
markam1955 is
has no status.
Junior Member
I have a similar problem with my 2005 model Grand Scenic.
I replaced the EVM solenoids, and this fixed it for a few weeks, but then the problem slowly came back again.
But the problem only occurs after the car has been left for a period of time ... over-night for example.
If I let the car run for a while (3 to 5 minutes) before driving off, no problem at all. And will continue to work just fine every time I use it, until I leave it for 4 or 5 hours without using it.
Was wondering if there could be a non-return valve in the fluid line somewhere which is leaking ? So requires time to rebuild pressure before working again properly ?
And it does seem to be a common problem with this particular model. My friend has exactly the same car, and his does it too. He has had the EVM solenoids replaced a few times, the gearbox has been out, and some "pan" in the middle of it has been cleaned, the fluid has been replaced several time etc etc. This always fixes it ... for a while, and then the problem comes back. Luckily his car is still covered by Renault warranty (the problems first ocured during the warranty period), so he's not having to pay for all this yet. Mine isn't.
Not sure if it is relevant, but the cars are in Malaysia ... so not the typical European climate
Any suggestions, theories etc etc most welcome. Its getting really annoying ...
Thanks, Mark
markam1955 is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to markam1955 For This Useful Post:
Gerry W (4th September 2011)
Old 27th July 2010   #4
artistjsb
artistjsb is
has no status.
Junior Member
Having read this and other forums on this auto gearbox problem I am not at all clear about whether I should be bothering to get mine 'fixed' or not. It sounds as if I would be spending £500 + in order to see a repeat of the problem at some point in the future. Is this problem dangerous or just inconvenient? Will the car be wrecked if I do nothing, or will it just carry on being an annoying issue I have to accommodate? Any comments on these questions will be most welcome.
Currently in artistjsb's garage:
2005 Grand Scenic 2l Automatic
artistjsb is offline   Reply With Quote Quick reply to this message
Old 8th October 2010   #5
Spanish Jag
Spanish Jag is
has no status.
Junior Member
We have a 2005 Scenic 1.6 petrol auto, yesterday it started dropping out of gear as I was driving at about 70 kmph. I pulled over and set off again and it did it again. I have spoken to several local Renault garages and none of them will even take a look at it because it is auto.
Today I have driven it, including on the motorway, without any problems. We are on the Spanish/Portuguese border and I spoke to a dealer in Portugal today who told me to take it to the dealer in Faro, where they will take the box out and ship it to Holland for repair!!!
Am I likely to damage it further by continuing to drive it and is there anything I can do to try and resolve it ie check gearbox oil etc etc
Spanish Jag is offline   Reply With Quote Quick reply to this message
Reply
Tags
auto, garage, gearbox, problem, recommendation, renault, scenic
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
