Espace Panoramic Sunroof - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Ask the Experts » Interiors
Notices
Interiors Discuss leaks, seats, carpets etc.
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Interiors
Reply
Thread Tools Display Modes
Old 23rd April 2010   #1
Anfieldred118
Anfieldred118 is
looking for answers
Junior Member
Anfieldred118's Avatar
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Typical when the sun shines the sunroof and interior blind plays up. I have a 05 plate Grand Espace.
I went to open it the other day and the blind went back as normal, the roof made the intial movement up but refused to go back but in the process it made some really loud clunking noises as though it had jumped the drive teeth( if there are any ). I managed to get the roof back down by pushing the button, when i tried to close the blind it now only goes 2/3 of the way back.
Has anyone had the same problem or does anyone know how to get to the mechanism to sort it out either by resetting it or stripping it down.
All help would be appreciated.
Currently in Anfieldred118's garage:
2005 Grand EspaceIV 2.2 dcI
Anfieldred118 is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by Anfieldred118
Espace Mk4 Suspension Rattle/Knock Steering and Suspension dcbain 2 425 9th September 2015 02:09 PM
Front Wishbone Identification Steering and Suspension Anfieldred118 0 681 3rd June 2013 08:58 PM
CD Head Unit Compatability Electronics Anfieldred118 2 879 14th June 2012 09:51 AM
Renault Espace MkIV Rear Brake Calipers Wheels & tyres tolsen 1 2967 16th May 2010 10:23 AM
Espace Panoramic Sunroof Interiors Keithwalker 10 7758 23rd April 2010 12:06 PM
Sponsored Links
Advertisement
Old 23rd April 2010   #2
ns.thomson
ns.thomson is
has no status.
Diamond member
ns.thomson's Avatar
Re: Espace Panoramic Sunroof
Just a thought have you tried opening the glass by using the button and giving it a little help by gently pushing it with your hand . Maybe there is an obstruction or needs a bit of grease. If you could get it open there might be a better chance of seeing what the problem is
Currently in ns.thomson's garage:
Rover in Garage, Grande Espace 2.2 Initiale on Drive
ns.thomson is offline   Reply With Quote Quick reply to this message
Old 26th April 2010   #3
Anfieldred118
Anfieldred118 is
looking for answers
Junior Member
Threadstarter
As an update, i've been experimenting with a few things and i've found that by holding the button in for about 10 secs the blind returned to the normal position. Subsequently i've been "working" both the blind and sunroof frequently and things are returning to normal. If either get stuck or misbehave in any way i simply keep the button pushed in for 10 secs and things reset.
I now think the mecahnism was simply in need of lubrication as it hadn't been used for a good few months.
Fingers crossed, problem solved.
The Following User Says Thank You to Anfieldred118 For This Useful Post:
ESPACE DRIVER 26 (29th August 2010)
Old 10th August 2011   #4
shawl01
shawl01 is
has no status.
Junior Member
Hi, I am new to this forum and as someone who has just purchased an espace (06) I wanted to enquire about peoples similar experiences with the sunroof.
On the one I have sometimes needs a little help to get past the first part of the movement, it is only sometimes and if you don't help it when it needs it it simply pauses and then goes back to closed (a bit like it's hitting a blockage)
The other thing is that when it's closing it judders, but seems to close fine.
A indi mechanic has looked at the motor as says it has a worn sprocket that connects the motor to the sunroof (I think he said it's nylon) but upon enquiring with Renault it's not available as a part and is a whole new motor. £550 seems a bit overkill for a sprocket?
Anyone else had any experiences like this?
Many thanks in advance
Luke
shawl01 is offline   Reply With Quote Quick reply to this message
Old 27th January 2014   #5
imwills
imwills is
has no status.
Junior Member
imwills's Avatar
I have the exact same problem with my 04 Espace. Did you guys find a cure?
Ian
Currently in imwills's garage:
2004 Renault Espace Expression 1.9Dci, 2000 Rover 75 2ltr Auto Connossieur SE, 1990 Rover Metro 1.4 GTA
imwills is offline   Reply With Quote Quick reply to this message
Reply
Tags
espace, panoramic, sunroof
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
