Changing injectors on a Clio MKII - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Search this Thread Display Modes
Old 1st May 2010   #1
rufnek2kx
rufnek2kx is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Hi Guys,
My clio has been juddering a lot recently on idle, I narrowed it down to a misfire on the fourth cylinder. The leads have been checked as well as a compression test on the cylinder in question and no problems seem to have arisen from them. I took it to a mechanic and after finding out the above, he said it is probably a faulty injector. I think this makes sense as I have read on this site that if it was the coil, 2 cylinders (first and fourth) would be misfiring together.
I have bought a 2nd hand rail + injectors for an X reg (mine is V) and I was just wondering whether the injectors could simply be swapped? I know that the ECU sends a signal to the injectors, but will it cause more problems if I swap them or should it work fine?
A second option I have thought of is to remove all 4 injectors that are in the car and get them ultrasonically cleaned. Has anyone done this before and is it any good or just another gimmick?
Any help at all is appreciated.
Currently in rufnek2kx's garage:
Renault Clio mkII Alize 1.4i 8v 5Dr V reg E7F
rufnek2kx is offline   Reply With Quote
5 Lastest Threads by rufnek2kx
Changing injectors on a Clio MKII Engines mungobungo2010 13 3757 1st May 2010 05:06 PM
Replacing Clio MKII Front Passenger door Bodywork rufnek2kx 3 1900 14th December 2009 07:35 PM
Sponsored Links
Advertisement
Old 2nd May 2010   #2
rufnek2kx
rufnek2kx is
has no status.
Junior Member
Threadstarter
Re: Changing injectors on a Clio MKII
Anyone?
Old 2nd May 2010   #3
bedford561
bedford561 is
has no status.
Diamond member
swapping all the injectors should be fine but you must swap all 4 as they should be flow matched from factory.and unlike the dci injectors they dont need to be coaded by renault.
second of all no ultrasonic cleaning isnt a gimmic i had mine done on my track civic type r and they work perfect now but its not cheap and i think there are only a couple of places that can do it i used abp motorsport to do mine and i belive they sourced it out to a company in derby.
Currently in bedford561's garage:
Renault clio 1.5 dci running 145 bhp at the wheels, civic type r ep3 track day car ''not road legal''
bedford561 is offline   Reply With Quote
Old 3rd May 2010   #4
Ralph
Ralph is
Laid back
Platinum member
Ralph's Avatar
Nominated 7 Times in 6 Posts
Nominated TOTW/F/M Award(s): 3
My Mood: Relaxed
If the injectors are not coded and I don't know if they
are then you could try swapping the bad one over with
one of the others see if the miss moves with it.
__________________
If you find a fix for your problem please post and let us
know the outcome it will help others with the same problem.
Please read this post and sign if you agree.
http://www.renaultforums.co.uk/showt...&highlight=mph
Ralph Nr Fleetwood NW UK.
Currently in Ralph's garage:
Clio 15 DCi 80, Motomorini 3 1/2 "Vicious little bugger", Suzuki Burgman 400
Ralph is offline   Reply With Quote
Old 3rd May 2010   #5
Lagdti
Lagdti is
back.....sort of...:o)
Veteran Member
Technical Supremo
Lagdti's Avatar
Nominated 16 Times in 16 Posts
My Mood: Stressed
Have you swapped the coils around?.If not,I'd do this before getting involved in changing the injectors.
If the coils check out OK,then you can swap either one or the complete set of replacement injectors you have.
__________________
I'd rather push my Alfa than drive a BMW....
Currently in Lagdti's garage:
2003 Alfa Romeo 156 2.4 JTD Sportwagen (estate to you and me!), 2002 Alfa Romeo 147 2.0TS Lusso soon to also be in many pieces,and now a 1994 Land Rover Discovery 300Tdi with a 2'' lift kit and some girt knobbly tyres on it....
Lagdti is offline   Reply With Quote
Reply
Tags
changing, clio, injectors, mkii
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © 2005-2009 RenaultForums
Inactive Reminders By Mished.co.uk and FTP-Anime.com
