Re: renault scenic 1 exhaust support?
hi which point is there the crack.
exhaust is made up of:
exhaust manifold, down pipe, catalytic converter, mid box, back box.
fittings are:
sprung loaded bolts between manifold and down pipe, down pipe and CAT are bolted together, there should be a renault sleeve fitting that fits between the CAT and midbox, joint between mid and back boxes is a compression clamp.
support hooks are on the mid box and back box.
__________________
I was depressed last night so i called lifeline.
I got through to a call centre in Afganistan.
I told them i was feeling suicidal.
They got very excited and asked me if i could drive a truck.
Currently in mord's garage: BMW X5 3.0D Sport, Fletcher ArrowFlyte 60hp SpeedBoat :)
