Screeching Squeaking noise from Drivers front wheel - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Ask the Experts » Wheels & tyres
Notices
Wheels & tyres Wheels, tyres, suspension etc.
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Wheels & tyres
Reply
Thread Tools Display Modes
Old 29th May 2010   #1
The Equalizer
The Equalizer is
has no status.
Junior Member
The Equalizer's Avatar
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Hey Y'all
I noticed a few months ago that my clio was emitting a squeeking noise when I turned right.
Not full lock turn, but even if i turn the steering wheel a few milimetres to the right.
It seems to stop when i apply the brake?
I went to take the Drivers side wheel off today to check it out as the noise is quite loud now & I noticed that the Hub Nut was Red Hot. I burnt my hand on it.
So I left it.
I'm thinking what would cause that heat?
Either Wheel Bearings or Brakes Binding maybe.
There is no noticeable pulling whilst driving. which would lead me to err on the side of the bearings, but there is no grinding noise & the wheel rotates ok.
Anyone got anything worth trying?
E
Currently in The Equalizer's garage:
Clio 98 1.2, Citroen C8 1.9 HDI, Renault Kangoo 1.9 Diesel 2000 W Reg
The Equalizer is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by The Equalizer
Kangoo 200 W Reg Front Brake Pads removal Wheels & tyres The Equalizer 4 4558 24th February 2011 02:43 PM
Kangoo Van Glow Plug Replacement Engines greg2246 5 8652 17th December 2010 07:40 PM
Place to buy Pentagonal Caliper Key? Please Wheels & tyres tolsen 5 3262 6th June 2010 09:32 PM
Screeching Squeaking noise from Drivers front... Wheels & tyres The Equalizer 4 7684 29th May 2010 04:15 PM
Rear Drum Removal Clio 98 Wheels & tyres The Equalizer 10 6641 24th May 2010 09:21 PM
Sponsored Links
Advertisement
Old 29th May 2010   #2
Lagdti
Lagdti is
back.....sort of...:o)
Veteran Member
Technical Supremo
Lagdti's Avatar
Nominated 1 Time in 1 Post
Re: Screeching Squeaking noise from Drivers front wheel
I'd remove the wheel and check the caliper and it's slides,also check the pads are free in the caliper carrier.It's very unusual for a bearing to get hot without being noisy so the brakes would be prime suspect at the moment.
__________________
I'd rather push my Alfa than drive a BMW....
Currently in Lagdti's garage:
2 Nissan Almeras.....oh joy is mine.....
Lagdti is offline   Reply With Quote Quick reply to this message
Old 29th May 2010   #3
The Equalizer
The Equalizer is
has no status.
Junior Member
Threadstarter
Cheers Lag (If I may call you that)
I'll have a go on Later in the week, as I am working now untill next Friday.
Cheers
E
Old 4th June 2010   #4
The Equalizer
The Equalizer is
has no status.
Junior Member
Threadstarter
Hey Guys
I was just having a look at my front brake pads wit ha view to taking them out to have a look & the caliper as well.
I found that I didn't have the right Allen key for the plate that covers the discs.
It looks like a 9mm allen key.
Never seen one of them?
Cant seem too see many on the Tinternet either.
Anyone confirm that its a 9mm Allen key I need.
I assume it is as my 8mm is too small & my 10 too big?
Many thanks
E
Old 6th June 2010   #5
The Equalizer
The Equalizer is
has no status.
Junior Member
Threadstarter
Its not a bloody Allen Key!
Thats why it won't fit.
Anyone know what size Caliper Key I need for my Clio?
E
Reply
Tags
drivers, noise, screeching, squeaking, wheel
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
