Semi-Auto Clio Problems - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 30th May 2010   #1
clairelou
clairelou is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
I'm at risk of making myself sound like a bit of a noob here, but I'm really getting quite desperate! Be kind to me, I've only been driving for 7 months, and really don't know much about cars, so being stuck with a car that probably should be called Herbie isn't ideal.
I bought a semi-auto Clio back in December and have had nothing but grief with it since, and every mechanic I've taken it to seem to be at a complete loss.
My driveway is on a slope, not a massive slope but the car doesn't like it, I put it into reverse and it rolls, and it picks up momentum very very quickly, this was an issue for me to begin with but I've now come to accept that there's nothing anyone can do for it (well so I've been told) and I deal with it. The car rolls on the slightest slope, and it struggles to go up if there is a slight upwards slope in the road, I'm not kidding, it's pathetic.
It's really quite jumpy when it changes gears usually between 1 and 2. And my rev count is getting higher and higher everytime I drive it between gears 1 & 3, and it seems to be more unwilling to change gear.
I have only driven it in manual once before, because I learnt in an automatic and only have an auto licence so the idea of having to change gears is a bit daunting for me, I know that legally I am allowed to drive it manually but I don't want to cause an accident with my lack of confidence!
A couple of months ago I had the factory settings restored and that made a small difference to the rolling and the easiness in gear changes for about 2 weeks.
Then yesterday I took it in for a service, picked it up and it was having none of it. Severe lack of acceleration to the point that my dad was driving round a huge roundabout at 2 miles an hour with his foot literally touching the ground. This has happened once before.
So needless to say it is currently back in the garage, but I'm at my wits end with it as I can't seem to go about a month or so without it ending up with a mechanic for one reason or another.
Sorry for the ramble, was just wondering if anyone else has experienced anything similar with semi-autos, or whether it is just my car that needs to be scrapped?
clairelou is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by clairelou
Semi-Auto Clio Problems Engines mishmash27 7 13483 30th May 2010 04:20 PM
Sponsored Links
Advertisement
Old 30th May 2010   #2
Haree
Haree is
has no status.
Diamond member
Nominated 0 Times in 2 Posts
Re: Semi-Auto Clio Problems
Hello Claire,
I am sorry to read about the problems you are having with your Renault Clio Quickshift. Whether or not there is an actual fault with the box I don't know, but these types of automatic are not too all tastes and can be quite different to driving a standard torque converter or CVT automatic. Please let me explain to you about the semi auto gearbox on your car. Your car has a 5 speed Quickshift automated manual gearbox. Basically the gearbox is manual and the clutch action is controlled to some extent automatically by an electro hydraulic actuator, so when you drive along in auto mode or in manual mode when the car changes gear or you change gear the clutch action is done for you. Now as the clutch on these to some extent is like a manual clutch, I know you learnt in an auto but when you are on an incline, if your foot is not on the accelerator pedal the 2 clutch plates are apart (like having the clutch depressed in a manual the 2 clutch plates are apart) and there is no drive to the wheels, so if you release the handbrake the car will roll backwards. What you should do is foot on foot brake, put the car into gear (manual or auto mode) and then apply a little accelerator as though you are doing a hill start as you would in a manual (but without the clutch), you will feel the clutch start to bite and then as the clutch plates bite release the handbrake and drive as you would normally. As far as gear changing in auto mode goes using gentle acceleration will give smoother gear changes and if you are driving around a bend or turning into a road slow down before and drive round with the car under power, do not lift off or ease off the accelerator as this can cause the box to shift up and the car to feel unsettled. Manual mode you can use when going up or down a steep hill or when driving around a series of bends where you don't want the box changing up and down on its own, you control the gears. If you are stopped in traffic, unless its just for a short time in which case holding on the footbrake is ok, then you should apply the handbrake and go into neutral. Do not leave in automatic or manual with the handbrake on or with the engine at high revs to balance the car on a hill as this will cause rapid wear to the clutch. When you are parking then park in gear, apply the hand brake and then switch off the engine. If the handbrake fails then the car will not roll back, like it would in neutral.
Hope this is of some help to you. Any questions just ask.
Harry.
Currently in Haree's garage:
I don't have a garage just a driveway. The Modus 1.6 16v VVT Dynamique Auto is my Grandparents car which I also drive.
Haree is offline   Reply With Quote Quick reply to this message
Old 31st May 2011   #3
acerproton
acerproton is
has no status.
Junior Member
i from malaysia using clio semi auto gear box. malaysia proton call savvy car. the problem is the indicator auto light on then the gearshifter cant change and jump to neutral gear. untill now nobody know what problem. dont know repair the problems..
malaysia is heavy rain and hot sun.
Currently in acerproton's garage:
renualt clio semiauto
acerproton is offline   Reply With Quote Quick reply to this message
Old 27th July 2011   #4
Rondon73
Rondon73 is
skint
Junior Member
Question Re: Semi-Auto Clio Problems
I have same problem with (2002 1.2 16v Clio). Any advice much appreciated?. Thought the reply to original question was excellent.
Many Thanks
Rondon
Currently in Rondon73's garage:
Ronnie Love
Rondon73 is offline   Reply With Quote Quick reply to this message
Old 27th July 2011   #5
acerproton
acerproton is
has no status.
Junior Member
Quote:
Originally Posted by Rondon73 View Post
Many Thanks
Rondon
i learn from my boss name william said just clean the speed sonsor.
Reply
Tags
clio, problems, semiauto
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
