2003 Semi auto clio *limp mode* - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Ask the Experts » Cars & motoring
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Cars & motoring
Reply
Thread Tools Display Modes
Old 12th June 2010   #1
Imposter01
Imposter01 is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
I'm new on here seeking help on my clio.
when i start it up it runs fine on tickover for a few minutes or 10 minutes then goes into limp mode.
when i start appling the throttle that speeds up the time it takes to go into limp mode.
when i put it in gear and drive it will drive for a few metres then go into limp mode.
ive nad a diagnosis done on it and it came back as throttle pedal, so i replaced this and its still in limp mode, and nothing showing on the diagnosis.
basicly when in limp mode i press the throttle and get nothing ?
Can anyone shed some light on what the fault is ?
Currently in Imposter01's garage:
2003 clio
Imposter01 is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by Imposter01
2003 Semi auto clio *limp mode* Cars & motoring Q1amp 3 2059 12th June 2010 01:26 PM
Sponsored Links
Advertisement
Old 12th June 2010   #2
Haree
Haree is
has no status.
Diamond member
Nominated 0 Times in 2 Posts
Re: 2003 Semi auto clio *limp mode*
Hello,
you have put in your post title that your clio is semi auto so I assume you are referring to the quickshift gearbox. Anyway if a diagnotics scan has been done and a faulty throttle pedal has been diagnosed (do you not mean throttle sender) maybe it needs to be programmed to the cars ECU and the fault cleared for the gearbox to function correctly. Have you tried it in manual mode to see if there is any difference.
Harry.
Currently in Haree's garage:
I don't have a garage just a driveway. The Modus 1.6 16v VVT Dynamique Auto is my Grandparents car which I also drive.
Haree is offline   Reply With Quote Quick reply to this message
Old 13th June 2010   #3
Imposter01
Imposter01 is
has no status.
Junior Member
Threadstarter
Yes the fault codes have been deleted and putting the gearbox into manual makes no differance, it will go into limp mode just standing there
2003 clio
Old 13th June 2010   #4
Q1amp
Q1amp is
has no status.
Junior Member
its very rare a pedal goes wrong, if its a 1200cc they suffer with throttle bodies and the loom to the throttle body, also theres a block connector in the fuse relay board by the battery which the throttle wiring runs through which can suffer with water ingress and poor continuity through the connector. Do you have the codes to hand? and what if any warning lights come on?
I`ve also seen brake switch faults just depends on the codes you`ve got.
hope this helps a bit
Q1amp is offline   Reply With Quote Quick reply to this message
Reply
Tags
auto, clio, limp, mode, semi
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
