Ball Joints for Master van - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Ask the Experts » Wheels & tyres
Notices
Wheels & tyres Wheels, tyres, suspension etc.
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Wheels & tyres
Reply
Thread Tools Display Modes
Old 1st July 2010   #1
linde1
linde1 is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Hi all.
Just wondering has anyone ever fitted ball joints to a renualt master van .I believe you can buy the ball joint separate and press it in to the wish bone ,rather then buying the complete arms which are rather expensive.
Currently in linde1's garage:
renualt master 2.5 x70
linde1 is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by linde1
Ball Joints for Master van Wheels & tyres Lagdti 2 6977 1st July 2010 11:30 AM
linde1 Welcome to RenaultForums dave_mezza2006 2 1053 1st July 2010 10:22 AM
Sponsored Links
Advertisement
Old 1st July 2010   #2
Donald
Donald is
mad
Platinum member
Technical Supremo
Fishing the Sea Champion
Donald's Avatar
Nominated 1 Time in 1 Post
Nominated TOTW/F/M Award(s): 11
Re: linde1
Quote:
Originally Posted by linde1 View Post
Hi all.
Welcome to the forum,
If its the case you can change the ball joint in a Renault Master?? then if its like other Renault models? it can only be done once!! then you have to buy a complete arm,
If you look at the ball joint itself on the under side???if it has a small indent on the outer edge than that normally points to being changed before and if thats the case then its a new arm iam afraid,
Hope this helps Donald
Currently in Donald's garage:
2005 Mercedes Benz C200 Classic SE Kompresser & 1998 Fiat Cinquecento Fire Sporting,some may say i could do far better?,i say i could do far worse.
Donald is offline   Reply With Quote Quick reply to this message
Old 2nd July 2010   #3
Lagdti
Lagdti is
back.....sort of...:o)
Veteran Member
Technical Supremo
Lagdti's Avatar
Re: linde1
What age is the Master?.
I've replaced 'a few' top and bottom joints on Masters/Movanos around the 2003-2005 mark and they have had to be pressed in and out of the top and lower arms.The one problem on these is that the lower arm is held in by a pin,this pin can seize in place and this can complicate the job massively.I have still changed the joints in arms where the pin has seized,but it involves a large socket and an even larger hammer and it's not for the faint hearted!.
__________________
I'd rather push my Alfa than drive a BMW....
Currently in Lagdti's garage:
2004 Saab 9-5 HOT Aero and a 2001 Audi A3 1.8 Turbo
Lagdti is offline   Reply With Quote Quick reply to this message
The Following 2 Users Say Thank You to Lagdti For This Useful Post:
SPIKE0982 (12th December 2013), Turbonoodle (7th January 2013)
Reply
Tags
ball, joints, linde1, master, van
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
