where to attach air con hose to recharge - Page 3 - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Ask the Experts » Heating & cooling
Notices
Heating & cooling A place to discuss heating, air-con etc.
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Heating & cooling
Reply
Thread Tools Display Modes
Old 29th March 2011   #11
madnoel10
madnoel10 is
has no status.
Technical Supremo
Nominated 12 Times in 65 Posts
Nominated TOTW/F/M Award(s): 26
Re: where to attach air con hose to recharge
The Scenic II doesn't have a low pressure air-con port - only one.
Recharging air-con systems using DIY kits is not recommended as it relies on judging pressure whereas air-con systems should be filled by weight and only after the system has been emptied under vacuuum.
Currently in madnoel10's garage:
Honda Civic 1.4l
madnoel10 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 31st March 2011   #12
Prestige_Decodes
Prestige_Decodes is
has no status.
Diamond member
Nominated 1 Time in 1 Post
TOTW/F/M Award(s): 0
Renault do have a low pressure port but in there wisdom they put a high pressure fitting on it so be very carfull if charging 1 as I have had to replace to many compressors due to ppl not knowing what they are doing and putting a
liquid charge into the wrong port and hydrolicen (wish I could spell) the compressor
Prestige_Decodes is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to Prestige_Decodes For This Useful Post:
alancee (26th June 2014)
Old 1st May 2011   #13
mcb
mcb is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
Did you find the low pressure air conditioning I am yet to find it on mine.
mcb is offline   Reply With Quote Quick reply to this message
Old 1st May 2011   #14
Prestige_Decodes
Prestige_Decodes is
has no status.
Diamond member
If you read the answer above there is only 1 port and it is the low pressure port but it has a high pressure fitting on it
Old 1st May 2011   #15
mcb
mcb is
has no status.
Junior Member
Hi sorry I was not using my eyes. Is there a DIY refill as the ones from the stores only do the small port. Also how do i know which is which as I only can see one.
Reply
Tags
air, attach, hose, recharge
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
