Cigarette Lighter not working properly renault clio 1.6 04 - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Electronics
Reply
Thread Tools Display Modes
Old 15th July 2010   #1
kezza2728
kezza2728 is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Looking for a few sugestions,
The Cigarette lighter in my car is not working properly,
it doesnt illuminate or charge phone or sat nav but if you push it down to use as a lighter it does work.
Any ideas?
Currently in kezza2728's garage:
2004 Clio 1.6 16V
kezza2728 is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by kezza2728
Chugging Clio 1.6 16V Engines Recycled Scenic 1 1348 17th February 2011 07:16 PM
Clio 04 1.6 Pollen Filter Engines FoxOkay 3 3631 8th February 2011 08:57 PM
Cigarette Lighter not working properly renault... Electronics ha5him 3 7178 15th July 2010 04:19 PM
Tweeters Clio II Electronics kezza2728 1 1523 6th April 2010 08:31 PM
Sponsored Links
Advertisement
Old 2nd August 2010   #2
giles89
giles89 is
has no status.
Junior Member
Re: Cigarette Lighter not working properly renault clio 1.6 04
I having the exact same problem, strat happenning after i changed my battery and a fuse... stereo, clock etc. all work fine, just the cigarette lighter
Help greatly appreciated
giles89 is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to giles89 For This Useful Post:
johnsongm (26th June 2011)
Old 3rd August 2010   #3
Carlos777uk
Carlos777uk is
has no status.
Member
Carlos777uk's Avatar
If the socket works to heat the cigarette lighter element then there's no reason it won't work to power a 12V device.
Have you tried a different adapter?
Check also the metal contact areas are clean enough to provide current flow to your charging adapter. Don't go poking anything in there though as it may be pre-ignition live i.e even if the ignition is turned off, this socket will be capable of sourcing current.
Currently in Carlos777uk's garage:
2002 Renault Scenic 1.9 dCi
Carlos777uk is offline   Reply With Quote Quick reply to this message
Old 27th December 2010   #4
ha5him
ha5him is
has no status.
Junior Member
i have exact same problem on my 54 megane. I/m a novice so can anyone tell me how i can check without poking anything in there? or is there any easy way to pull out and clean?
Also just went through the car manual and got the impression the cigarette lighter & 12v socket are different on some models.
Page 153 (3.29) Accessories socket: Depending on the vehicle the cigarette lighter can also be used as a 12v accessories socket.
Just don't want to go fiddling around if i need to change the socket.
Thanks for any help you guys can provide cheers H
Currently in ha5him's garage:
54 Megane Expression 1.5dci
ha5him is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to ha5him For This Useful Post:
kezza2728 (8th February 2011)
Reply
Tags
cigarette, clio, lighter, properly, renault, working
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
