clio 1.5dci 65 tuning - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 29th July 2010   #1
llama_boi626
llama_boi626 is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
hi, i have a clio 1.5dci 65 does this have a turbo? and was wandering if fitting an intercooler and ONLY an intercooler would make a difference in horses? and are there any restrictors on the engines that can be easily removed. thanks
Currently in llama_boi626's garage:
2003 renault megane 1.9 dci 120
llama_boi626 is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by llama_boi626
megane sunroof, window, locking + other problems... Electronics llama_boi626 0 917 19th April 2012 01:38 AM
clio 2003 pulling to the left with good tracking Cars & motoring llama_boi626 0 1597 11th March 2011 03:23 AM
clio 2003 cd player getting louder by itsself Electronics llama_boi626 0 671 13th February 2011 08:16 PM
speedo noise clio Electronics Ralph 6 1292 5th February 2011 01:54 AM
dci injector coding and boost pressure raise? Engines madnoel10 2 2047 13th January 2011 04:46 AM
Sponsored Links
Advertisement
Old 29th July 2010   #2
gtv
gtv is
still here
Diamond member
gtv's Avatar
Re: clio 1.5dci 65 tuning
Hi there and welcome to the site, yes the 65bhp does have a turbo.
As for just adding an intercooler i am not sure tbh, they do this lump with 65,80 and 100bhp and the main dif is the other two have intercoolers, dif turbo's and injectors + maps.
Hope that helps a little.
__________________
Currently in gtv's garage:
Clio Dci 1.5 65bhp
gtv is offline   Reply With Quote Quick reply to this message
Old 9th August 2010   #3
MATT BLACK
MATT BLACK is
has no status.
Member
MATT BLACK's Avatar
The 65 and the 80 use the same turbo ( 5435 970 0002 Borg warner K series ) If you want extra power just fit a set of 80 bhp injectors - its as simple as that !!
( 80BHP EJBR01801A as suppose to the 65BHP injectors EJBR01401Z )
A remap may help give a little extra power
You could fit an intercooler but it wouldnt really do much on such a low power engine.
We run a DCi65 bhp Clio courtesy car with the 80 bhp injectors and it goes like snot of a stick !!
Currently in MATT BLACK's garage:
Various Renaults
MATT BLACK is offline   Reply With Quote Quick reply to this message
Old 9th August 2010   #4
mickpm
mickpm is
misses Rod Hull
Diamond member
mickpm's Avatar
Matt, aren't the injectors spray patterns coded on the various Renault K9K-7xx 1.5DCi platforms?
I know they're not on the variants that use the same engine in 1.4TDCi format [i(Ford/Peugeot, Mazda)[/i] but then again they don't run different power outputs. Genuine question as I've never had to swap jets on a Clio or Kangoo (yet) so haven't ever looked in to it.
Currently in mickpm's garage:
1992 BTCC 19 16v
mickpm is offline   Reply With Quote Quick reply to this message
Old 11th August 2010   #5
llama_boi626
llama_boi626 is
has no status.
Junior Member
Threadstarter
Smile Re: clio 1.5dci 65 tuning
thanks for writing back, i hear about doing that but i also heard they are coded to the ecu, sounds like a good idea though. cheers
Reply
Tags
15dci, clio, dci 65, intercooler, tuning, turbo
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
