Renault Scenic radio code entered but still locked - Page 3 - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Electronics
Reply
Thread Tools Display Modes
Old 3rd July 2010   #11
mcouchard
mcouchard is
has no status.
Diamond member
mcouchard's Avatar
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Red face Re: Renault Scenic radio code entered but still locked
Well I have had the code confirmed by an online electronics site and it is exactely the same code I the scrappy gave me and have been trying .
so either ther is omething wrong with the stereo or I am missing something out.
Any ideas appreciated,
Thanks, Matthew
Currently in mcouchard's garage:
2001 Renault Megane 1.4 16v Expression & 2002 Volvo V40 1.8S. 2000 Renault Megane 1.4 16v alize has been replaced and will be missed :(h
mcouchard is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 3rd July 2010   #12
madnoel10
madnoel10 is
has no status.
Technical Supremo
Nominated 12 Times in 65 Posts
Nominated TOTW/F/M Award(s): 26
If either the wrong code is entered or is entered incorrectly then the radio will lock you out for around 5 minutes the first time. This period doubles on each occasion up to a maximum of around 2 hours but the radio needs to be left switched on for its internal clock to calculate the time. So try leaving the radio switched on and see if it resets and try again.
Something in the back of my mind makes me think the wiring may have to be altered to suit a more modern unit. I could be wrong but no doubt someone will correct me.
Currently in madnoel10's garage:
Honda Civic 1.4l
madnoel10 is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to madnoel10 For This Useful Post:
mcouchard (4th July 2010)
Old 4th July 2010   #13
mcouchard
mcouchard is
has no status.
Diamond member
mcouchard's Avatar
Thanks Noel, unfortunately the radio won't stay on for a long enough period of time I turned in on tried the code and then went inside for just over an hour twice and when I came it out it had switched itself off both times.
I just find it very odd that when I revert bcak and insert the old tape deck it works straight away till without the insertion of any code. And this one won't accept its code that I have had verified form another source as well as the scrap yard.
Looks as if I will just have to pay the return postage, which willbe a fair bit I assume.
Matthew
Old 4th July 2010   #14
mcouchard
mcouchard is
has no status.
Diamond member
mcouchard's Avatar
Question Re: Renault Scenic radio code entered but still locked
In fact not only does the code not require enterring when I reinsert the old tape deck it also remembers the radio station preset's. So I'm wondering if there is a memeory other than that in the stereo itself tha I somehow need to clear inorder for it to accept the new cd player.
Also the baterry terminals appear to be quite firm, I removed the coupe consol fuse when nstalling the player is their anoher fuse I could remove that might make it clear the stereo memory?
Old 4th July 2010   #15
madnoel10
madnoel10 is
has no status.
Technical Supremo
Quote:
Unless the ignition is switched on the radio automatically switches itself off after 15 or 20 minutes as it is designed to do.
Honda Civic 1.4l
Reply
Tags
code, entered, locked, radio, renault, scenic
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
