Megane II boot release mechanism fail - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Electronics
Reply
Thread Tools Display Modes
Old 1st August 2010   #1
jojonic
jojonic is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Hi, have searched other threads but havent found one which will help my situation...
Just bought an 03 megane dCi, had some trouble opening boot when viewing but the owner went straight up to it and opened straight away. I presumed I was being useless and went away happy, but tried again to open when we got home and found it impossible. The button seems to be missing from inside the rubber cover... when you press your finger up it goes up a really long way and you can feel sharp metal connectors inside. It doesnt work from the button on the key card, I have managed to open it once by getting a metal screwdriver inside the rubber cover and making a connection manually, but this was more luck than judgement and am finding it difficult to make it happen again!
2 questions - 1. is there a manual override somewhere, where I can use the key to open the boot?
2. do I need to replace the whole mechanism or can I just get a new 'button' to put over the connectors (seeing as the solenoid seems to be working fine, kind of) and if so does anyone have a linky to help me buy one pls?
Have searched the web for the part but just keep coming up with offers for scenic boot buttons (which I wish I had found 2 months ago when the button popped out of our old scenic)
thanks in advance for help.
Jo
Currently in jojonic's garage:
2003 Renault Megane 1.5dCi
jojonic is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by jojonic
Megane DCi (80) 2003 - Turbo fitting help? Engines mr espace 1 1447 24th February 2012 08:07 AM
Megane II boot release mechanism fail Electronics owenstringer 3 6437 1st August 2010 01:32 AM
Sponsored Links
Advertisement
Old 1st August 2010   #2
owenstringer
owenstringer is
Taking my private pilots liscence
Diamond member
Re: Megane II boot release mechanism fail
Hello there, there is no overide as far as i am aware, u can open the boot from inside the boot. its defonatly just your switch that is causing the problem, i had the same problem with water ingress. to romove the switch you have to remove the panel from he inside of the boot and then remove the bottom part of the boot buy unsrewing it with star shape driver, it may be that you can repair your button but im sure they ae not to expensive from renault and they really are easy to replace, if you need a more detailed intruction on how to remove the switch please post back asking and ile be happy to help. owen
Currently in owenstringer's garage:
Megane 2 1.6 dynamique 2004
owenstringer is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to owenstringer For This Useful Post:
jojonic (1st August 2010)
Old 1st August 2010   #3
jojonic
jojonic is
has no status.
Junior Member
Threadstarter
Thanks Owen, will get on to a few breakers or Renault and get a new switch then. If I get stuck when trying to swap them over I'll give you a shout!
Jo
Old 1st August 2010   #4
owenstringer
owenstringer is
Diamond member
Not a problem i am happy to help you, just post me if you need any help, owen
Reply
Tags
boot, fail, mechanism, megane, release
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
