Brakes - Laguna, soft pedal and pedal fade - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Ask the Experts » Brakes/Hubs
Notices
Brakes/Hubs Brakes, Hubs, and etc
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Brakes/Hubs
Reply
Thread Tools Display Modes
Old 2nd August 2010   #1
NeilGB
NeilGB is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Question Brakes - Laguna, soft pedal and pedal fade
I have recently refitted the engine to my laguna II 2002 1.9 DCI. All is fine apart from the brakes.
With the engine off the pedal is fine, as soon as I start the car the pedal is soft and goes to the floor if not touched for a short time. The pedal will go hard if you pump it but fades as you hold pressure on it.
I have bled about 1.5 litres of fluid by using the pedal and then with a vacum pump.
I have checked the vaccum pipes and the non-return valve on the servo.
With the engine running and the pedal bad as soon as I disconnect the vaccum pipe to the servo it works fine (hard, no fade). Once the pipe is reconnected it goes bad again.
I am stuck on what could be wrong. I thought maybe the servo could be leaking inside or with the added pressure of the servo working it could be pushing past seals on the master cylinder but with the servo off and heavy pressure on the pedal it does not fade at all.
Any ideas or help greatfuly received!!!
Neil
NeilGB is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by NeilGB
Laguna II DCI oil problem Engines NeilGB 2 739 10th August 2011 11:45 AM
Brakes - Laguna, soft pedal and pedal fade Brakes/Hubs NeilGB 10 3471 2nd August 2010 07:51 PM
Sponsored Links
Advertisement
Old 3rd August 2010   #2
saabguy
saabguy is
fed up with working.
Platinum member
saabguy's Avatar
Nominated 1 Time in 1 Post
Nominated TOTW/F/M Award(s): 4
Re: Brakes - Laguna, soft pedal and pedal fade
Sorry to ask the obvious question but did you follow the correct left to right, front to back procedure most cars require when bleeding the brake system? Brake slave cylinders are plastic these days and have a tendency to fail causing your symptoms, the Laguna is no exception to this i'm afraid.
Currently in saabguy's garage:
2002 Citroen C5 SX 2.2 HDi
saabguy is offline   Reply With Quote Quick reply to this message
Old 3rd August 2010   #3
NeilGB
NeilGB is
has no status.
Junior Member
Threadstarter
Yes I bled n/s rear, o/f front, o/f rear, n/s front as advised in Haynes manual.
I have since bled again with a system that uses the tyre pressure and it was all ok. It seems a little bit better but might be wishful thinking!
I test drove the car last night and it will emergency stop or do gradual breaking fine, but still fades and feels spongey.
Old 3rd August 2010   #4
Lagdti
Lagdti is
back.....sort of...:o)
Veteran Member
Technical Supremo
Lagdti's Avatar
How long was the car apart for?.If it's been sat around for some time then the pads may have seized into the caliper carriers or the caliper slides may be seized.
__________________
I'd rather push my Alfa than drive a BMW....
Currently in Lagdti's garage:
2004 Saab 9-5 HOT Aero and a 2001 Audi A3 1.8 Turbo
Lagdti is offline   Reply With Quote Quick reply to this message
Old 14th August 2010   #5
Lagdti
Lagdti is
Veteran Member
Technical Supremo
Lagdti's Avatar
Any news Neil?.Have you got anywhere with the problem?.
Reply
Tags
brakes, fade, laguna, pedal, soft
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
