Possible Espace ABS Pump Problem - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Ask the Experts » Wheels & tyres
Notices
Wheels & tyres Wheels, tyres, suspension etc.
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Wheels & tyres
Reply
Thread Tools Display Modes
Old 2nd August 2010   #1
snoz
snoz is
HAPPY!!
Junior Member
snoz's Avatar
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Have plugged in my trusty code reader and have had the following codes appear:
ABS:
1. 10D (memory) - pump motor circuit, permanent control of pump motor or open circuit.
1. 10D (memory) - pump motor circuit, no rotation of pump motor.
Can anyone point me in the right direction to whats wrong or this means please?
Currently in snoz's garage:
1993 Espace 2Ltr RT Inj (Just sold for £400 on ebay!!!) and 1998 Espace Mk3 2Ltr auto RT-X
snoz is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by snoz
Espace Mk3 1998 Auto Gearbox Problem Transmissions snoz 3 2416 18th August 2010 09:11 PM
Possible Espace ABS Pump Problem Wheels & tyres snoz 4 4420 2nd August 2010 08:01 PM
Espace Coil Pack Replacement Engines snoz 5 2032 2nd August 2010 01:53 PM
Early Renault OBD problems? Look here! Tools & equipment Lagdti 6 10166 14th June 2010 12:24 PM
1998 Mk3 Espace 2ltr auto problem Electronics snoz 1 1330 6th June 2010 12:39 PM
Sponsored Links
Advertisement
Old 3rd August 2010   #2
snoz
snoz is
HAPPY!!
Junior Member
Threadstarter
snoz's Avatar
Re: Possible Espace ABS Pump Problem
As an addittional thought, to my knowledge this has only come on since the brake switch under the pedal was cleaned up after brake lights were found to not be coming on whilst depressing the pedal. Could this have any consequences?
Old 3rd August 2010   #3
Lagdti
Lagdti is
back.....sort of...:o)
Veteran Member
Technical Supremo
Lagdti's Avatar
Nominated 1 Time in 1 Post
As both of the codes are in the memory rather than present at the time of the code read,do they clear and then come back at all?.
__________________
I'd rather push my Alfa than drive a BMW....
Currently in Lagdti's garage:
2004 Saab 9-5 HOT Aero and a 2001 Audi A3 1.8 Turbo
Lagdti is offline   Reply With Quote Quick reply to this message
Old 4th August 2010   #4
snoz
snoz is
HAPPY!!
Junior Member
Threadstarter
snoz's Avatar
Hi Lagdti,
I have cleared the two codes and the only one to reappear is the:
But this alternates between active, memory and not reappearing. As far as I can tell the brakes work fine, but any tests you could reccommend and the expected outcomes or telltales of faults would be appreciated.
Old 4th August 2010   #5
snoz
snoz is
HAPPY!!
Junior Member
Threadstarter
snoz's Avatar
Ps. None of the warning lights/screens have lit up about an ABS fault, but I am sure they do work as they have alerted me to other faults.
Reply
Tags
abs, espace, problem, pump
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
