Megane II 1.9 DCI Fault Codes - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 11th August 2010   #1
stephensonrn
stephensonrn is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
I have a 55 plate Renault Megane II. It is the 1.9 DCI 130, engine code F9Q 800.
I get the service light and the check injectors message when I start from cold. After a couple of minutes, I can turn the engine off and then on again and the service light goes off with no "check injectors" message.
I have been to an independent garage and they have given me a report which shows the following codes:
DF025 Pre-postheating unit diagnostic line
DF118 EGR Solenoid Valve Control
DF272 EGR Valve Control
DF049 Refigerant pressure/temperature sensor
DF272 EGR valve control
The garage is not sure of the problem and will have another look next week. They said it struggled to start, even though it starts every time.
Any snippets of information will help. Can I ignore the DF049 because it is the aircon? Is the DF025 a suggestion of a glowplug, hence why the fault goes when warm? Could this fault be linked with the EGR valve, so should I drive it hard to clear it?
Currently in stephensonrn's garage:
2005 Megane II 1.9 DCI 130 F9Q800
stephensonrn is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by stephensonrn
Megane II 1.9 DCI Fault Codes Engines stephensonrn 1 9997 11th August 2010 09:26 PM
Sponsored Links
Advertisement
Old 27th September 2010   #2
stephensonrn
stephensonrn is
has no status.
Junior Member
Threadstarter
Re: Megane II 1.9 DCI Fault Codes
I bought 4 glow plugs online and managed to change 3 that I could get to. This solved the problem. I now have a full 72000 mile service to look forward to!
Reply
Tags
1.9 dci, codes, dci, fault, fault codes, megane
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
