megane fuse box ??? - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
megane fuse box ???
Electronics
Reply
Thread Tools Display Modes
Old 13th August 2010   #1
b3z99
b3z99 is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
megane fuse box ???
Hi im new and have a 1996 megane 1.4 rt and the fuse box has a break in the circuit board but i have been told to change the fuse box i also have 2 do ecu and key is this correct ?
b3z99 is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by b3z99
megane fuse box ??? Electronics b3z99 9 5489 13th August 2010 11:42 PM
Sponsored Links
Advertisement
Old 14th August 2010   #2
mickpm
mickpm is
misses Rod Hull
Diamond member
mickpm's Avatar
Re: megane fuse box ???
Hi B3z, i'm afraid this is correct - The 'ECU' and 'UCH' (Part of the fusebox) on this vehicle are "paired" and you'll need these plus the IR/RF plip keyfob that is sync'd to the UCH. You don't have to go as far as changing the key "blade" and lockset though.
If you do this you will obviously need a matching set from a single doner car of the same age and specification.
Mick
Currently in mickpm's garage:
1992 BTCC 19 16v
mickpm is offline   Reply With Quote Quick reply to this message
Old 14th August 2010   #3
b3z99
b3z99 is
has no status.
Junior Member
Threadstarter
and i take it the 1.6 ones aint compatible
Old 14th August 2010   #4
mickpm
mickpm is
misses Rod Hull
Diamond member
mickpm's Avatar
Providing the spec is the same then yes but if you've got dual optic lights and the doner car only has single optics, or AC vs Non-AC the UCH is gonna be setup for options that you don't have and will cause problems.
Best go like for like!
1992 BTCC 19 16v
Old 14th August 2010   #5
b3z99
b3z99 is
has no status.
Junior Member
Threadstarter
ok ive been scrappy got a ecu exactly same numbers fuse box but this vehicle did no have the black pick up between the sunvisors so i open the key to find a chip inside so i took the ring from round the steerin wheel fitted all this to my vehicle and ive got my hazards and everythin back but still no start flashin ecu light now ???? is there nethin else i have to change
Reply
Tags
box, fuse, megane
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
