Renault Clio II - Electronics - TDC sensor - Renault Forums :: Independent Renault forum
Go Back   Renault Forums :: Independent Renault forum » Problem Solving » Read our Articles » Clio
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Clio
Reply
Thread Tools Search this Thread Display Modes
Old 24th August 2005   #1
gwynne61
gwynne61 is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
I've a Clio 2 1.2 16v which has had starting problems. The AA have said the TDC sensor needs to be replaced as it is quite a straightforward job, can anyone advise me where the sensor is positioned before I start to pull things around. I know its on the gearbox by the flywheel but it doesn't seem readily visible. Any diagrams would be great.
Thanks in advance
gwynne61 is offline   Reply With Quote
5 Lastest Threads by gwynne61
Renault Clio II - Electronics - TDC sensor Clio dwe1962 71 74037 24th August 2005 03:42 PM
Sponsored Links
Advertisement
Old 24th August 2005   #2
WebCode
WebCode is
Here
Diamond member
WebCode's Avatar
Nominated 7 Times in 6 Posts
Nominated TOTW/F/M Award(s): 6
It is located on top of the gearbox casing where it meets the engine block..
It is held in by two 10mm bolts and has a two wire connector plugged into it..
It is relatively easy to remove but may require some coolant pipes to be moved to the side to help access..
__________________
EX Renault Dealer Technician & MOT Tester, Not a Monkey!
For as long as but one hundred of us remain alive, we will never on any condition submit to the domination of the English.....It is not for glory, nor riches, nor honours that we fight, but for freedom alone, which no good man gives up except with his life. Arbroath 1320
Currently in WebCode's garage:
MK1 Facelift Megane Cabriolet Sport
WebCode is offline   Reply With Quote
Old 24th August 2005   #3
FrenchFanRTE
FrenchFanRTE is
has no status.
Member
FrenchFanRTE's Avatar
Just to add, may be worth fitting a new connector for the sensor also while youre at it, your dealer should know what you mean, cut the old connector off, it's only two wires, so not to complicated to wire the new one in.
Also remove the air filter box, that'll help you to see what youre doing.
Currently in FrenchFanRTE's garage:
2007 Clio III 1.2 TCE Dynamique
FrenchFanRTE is offline   Reply With Quote
Old 29th August 2005   #4
gwynne61
gwynne61 is
has no status.
Junior Member
Threadstarter
Thanks for the help mission accomplished
Old 13th September 2005   #5
ginge594
ginge594 is
has no status.
Junior Member
Quote:
Thanks in advance
Could you tell me more about the fault, I just bought a W plate 1.2 grande, which has a intermitant starting fault, some times its like the imboliser has activated, but the veh will bump start, also the starter seems lazy at times.?
ginge594 is offline   Reply With Quote
Reply
Tags
clio, electronics, renault, sensor, tdc
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © 2005-2009 RenaultForums
Inactive Reminders By Mished.co.uk and FTP-Anime.com
