1999 megane 1.6 stopped and won't start - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 29th August 2010   #1
jacko1950
jacko1950 is
on line
Member
jacko1950's Avatar
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Don't know if this is related, but 3 days ago after heavy rain footwell had 3" of water in. Anyway cleared all that, car drove fine, no problems. yesterday driving fine, stopped at lights, set off a bit sluggish but was downhill so thought nothing of it, got to corner and no power steering, then noticed all warning lights on, ie car had stalled, so rolled her to kerb. Tried to start her, engine turns fine but doesn't start up, no warning lights, full tank of fuel. Had new TDC in january...any help appreciated
Currently in jacko1950's garage:
1999 T reg 1.6 sport. 8v. (K7M)
jacko1950 is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by jacko1950
Rear Indicator problem Electronics jacko1950 13 1656 24th January 2014 12:50 PM
Wheel bearing getting noisier... Brakes/Hubs jacko1950 12 1768 10th December 2013 07:25 PM
Another bonnet stuck.. Bodywork jacko1950 4 1396 5th August 2013 03:01 PM
what sort of spark plug ? Engines hondo 3 738 4th July 2013 10:24 AM
sensors -1999 megane 1.6 16v Electronics jacko1950 21 3824 4th December 2012 05:10 PM
Sponsored Links
Advertisement
Old 29th August 2010   #2
mickpm
mickpm is
misses Rod Hull
Diamond member
mickpm's Avatar
Re: 1999 megane 1.6 stopped and won't start
If it has had a *new* crank position sensor in January you still shouldn't rule it out i'm afraid especially if it wasn't a genuine part.
They're cheap and chearfull but ideally the car wants a diagnostic to say for sure what's occured. No warning lights and no firing - I bet its the CPS again.
Mick
Currently in mickpm's garage:
1992 BTCC 19 16v
mickpm is offline   Reply With Quote Quick reply to this message
Old 29th August 2010   #3
jacko1950
jacko1950 is
on line
Member
Threadstarter
jacko1950's Avatar
Mick
You could be right. It does crank but won't fire. and all lights come on and go off as normal, electrics all work ok, red light goes out okay. Just won't ignite. Worrying how this just happens out of the blue with no warnings or tell tale signs before hand. What is a CPS ??
Old 30th August 2010   #4
mickpm
mickpm is
misses Rod Hull
Diamond member
mickpm's Avatar
The "Crank Position Sensor" or "CPS" is what you refer to as the "TDC Sensor"
Its main function is to recognise engine rotation and report the Cranks position back to the ECU so that it can 'run' the fuelling and ignition programs. No sensor value = no start as the ECU cannot tell the engine is 'cranking'!
1992 BTCC 19 16v
The Following User Says Thank You to mickpm For This Useful Post:
jacko1950 (30th August 2010)
Old 30th August 2010   #5
jacko1950
jacko1950 is
on line
Member
Threadstarter
jacko1950's Avatar
Okay, thanks. I've been thinking...I had a new cat fitted 3 weeks ago...could that just be a coincidence...anything I should check ? Also, the first thing I noticed was power steering gone,
(but it could have stalled before) would the ECU shut down the engine of there was a fault in the PS system ?
Reply
Tags
megane, start, stopped
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
