Clio 2 Driveshaft replacement - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 5th September 2010   #1
clio83
clio83 is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Thumbs down Clio 2 Driveshaft replacement
So my plan for this weekend was new front discs, pads & a new passenger-side driveshaft as my current shaft's outer CV is split.
After fighting with the torx disc retention screw on the passenger-side brake disc, got the discs and pads done yesterday evening/this morning (see post on 'wheels' forum ref caliper bolts).
I have spent a small fortune on new driveshaft, gear pullers, ball joint separators, impact drivers, etc (have not done much previous maintenance so have not previously needed these tools).
And now I just CANNOT shift the driveshaft retention bolt! I haven't got a very big hammer, but using my impact drive with my biggest hammer is rotating the impact driver round, but not moving the socket at all! The Haynes manual makes no mention of a left-hand thread or anything, so I'm assuming anti-clockwise is the right direction to turn to remove the nut.
Is this a common issue, or have any experienced folk got any ideas? I expected it to be tight, but not this tight!
I'm giving it up as a bad job for this weekend, my car is still in one piece but I don't need it this week anyway.
Also, those of you who have done this yourselves, do you all re-tighten the (new) nut to the Haynes-recommended torque of 280Nm? That is a LOT (although I do appreciate the significance of keeping this joint secure!).
Currently in clio83's garage:
'99 Clio II
clio83 is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by clio83
Clio 2 Driveshaft replacement Engines bobsy 6 8136 5th September 2010 05:10 PM
Girling Caliper Retention Bolts Wheels & tyres clio83 2 1039 5th September 2010 09:30 AM
Sponsored Links
Advertisement
Old 5th September 2010   #2
madnoel10
madnoel10 is
has no status.
Technical Supremo
Nominated 12 Times in 65 Posts
Nominated TOTW/F/M Award(s): 26
Re: Clio 2 Driveshaft replacement
You'll need a knuckle bar at least 600mm long to undo the big nut - even then I have seen them break. Sometimes a piece of scaffolding tube to extend its length may work. Yes they are eff*** tight. Also the nut should be renewed each time - it is a once only fitting.
It may we worth paying a garage or tyre depot who have access to a good heavy duty impact driver to undo the nut and re-tigtnen to a lesser torque but you would be advised to drive slowly and carefully until full repairs have been carried out.
Currently in madnoel10's garage:
Honda Civic 1.4l
madnoel10 is offline   Reply With Quote Quick reply to this message
Old 5th September 2010   #3
clio83
clio83 is
has no status.
Junior Member
Threadstarter
Thanks,
due to my lack of heavy-duty maintenance experience, all I have is a piddly 1/2" drive foot-long or so breaker bar.
Thought a manual impact driver would be enough to loosen it, but obviously not with my upper-body strength!
'99 Clio II
Old 2nd February 2011   #4
itr-oz
itr-oz is
has no status.
Junior Member
Sorry for hi-jacking your thread, but it seems your question is semi answered so thought you might not mind?
My clio 1.5 dci 65bhp has im sure buggered cv joints, both sides. Theres a knocking when accelerating round corners (doesnt happen if i just kinda roll round the corner though?)
Now on this clio can you replace JUST the CV joints or is it the whole driveshaft? if so if I were to buy the drive shaft off say eurocarparts will that have everything I need including the cv joint etc? just a case of "plug and play"
Advice will be highly appreciated.
ITR-OZ
Currently in itr-oz's garage:
2002 renault clio 1.5 dci 65 bhp
itr-oz is offline   Reply With Quote Quick reply to this message
Old 15th July 2014   #5
bobsy
bobsy is
determined to see how long a PH1 will last!
Member
Hi, I have the same problem as the vehicle above ^^ in my 1.2 '98 Mk2 PH1 clio.
If I accelerate while turning on full lock mostly I get a knocking from the front of the car. It seems to happen turning in either direction.
Will driveshafts from ECP be sufficient or does it have to be a Renault part?
How do I determine which side is defective?
Currently in bobsy's garage:
Renault Megane PH1 1.6l
bobsy is offline   Reply With Quote Quick reply to this message
Reply
Tags
clio, driveshaft, replacement
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
