camshaft sensor location on megane 1.5dci - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 8th September 2010   #1
lane4king
lane4king is
has no status.
Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
hi guys..anyone tell me where the camshaft sensor is located on a 2003 megane 1.5 dci ?...picture would be nice...ta..also where is the TDC sensor?....are both easy DIY jobs ?
lane4king is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by lane4king
megane 2 1.5dci cranshaft sensor Engines lane4king 5 5434 30th April 2011 09:17 PM
time to change discs and pads ? Wheels & tyres planmeca 8 1853 20th April 2011 10:56 PM
glow plug removal socket Engines lane4king 4 2923 13th April 2011 09:38 AM
megane 2 dci 1.5 lumpy idling Engines lane4king 2 1712 10th April 2011 09:47 AM
megane 1,5 dci "injection fault" Engines lane4king 2 3240 8th April 2011 11:04 PM
Sponsored Links
Advertisement
Old 8th September 2010   #2
roby37
roby37 is
has no status.
Diamond member
Nominated 1 Time in 1 Post
Re: camshaft sensor location on megane 1.5dci
The camshaft sensor is easy, on the cambelt cover facing into the fuel pump pulley, held with one 10mm headed set bolt.
Everyone knows where the tdc sensor is, at 12 o'clock on the clutch housing and bolted to the block by two 10mm headed set bolts. Only, on the 1.5dci (or my 05 at least) it is not there. Located about 2 o'clock on clutch housing and secured by one 10mm headed set bolt. Access from below or from above after removing battery and ecu..
Currently in roby37's garage:
2005 Grand Scenic 1.5dCi
roby37 is offline   Reply With Quote Quick reply to this message
Old 8th September 2010   #3
Lagdti
Lagdti is
back.....sort of...:o)
Veteran Member
Technical Supremo
Lagdti's Avatar
The 'camshaft sensor' is a bit of an oddity on the 1.5 dCi engine,as Roby says it runs off the fuel pump pulley rather than the camshaft.
God bless the French.
Currently in Lagdti's garage:
2004 Saab 9-5 HOT Aero and a 2001 Audi A3 1.8 Turbo
Lagdti is offline   Reply With Quote Quick reply to this message
Old 8th September 2010   #4
lane4king
lane4king is
has no status.
Member
Threadstarter
thanks guys ..will have a look to see if i can change it...my renault megane..judders when driving, then suddenly the engine cuts out..wait about 15 minutes and it starts up and drives fine again....has happened about twice in the last 6 days...have no problems starting and idles fine, you can just notice the odd hiccup when idleing now and then....been told to change the camshaft sensor....how much are these parts to buy..?
Old 2nd December 2011   #5
cl!o
cl!o is
has no status.
Junior Member
Hi, Just had my Timing Belt replaced however my clio takes a few turns to start the engine and it starts easier if the clutch is pressed, upon further investigation I have noticed the Camshaft Sensor is loose and missing the bolt, does anyone have the part number or what the bolt looks like, the mechanic that fitted the belt is located 70miles away.
Many thanks in advance.
cl!o
cl!o is offline   Reply With Quote Quick reply to this message
Reply
Tags
15dci, camshaft, location, megane, sensor
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
