vivaro black smoke problem - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 17th September 2010   #1
craiganderson
craiganderson is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
HI CAN ANYONE HELP OR ADVISE ME OF WHAT TO DO WITH MY VIVARO VAN (APART FROM SET IT ON FIRE!) IVE HAD AN RE-CON ENGINE PUT IN A FEW MONTHS AGO THATS THE BLOCK AND HEAD, ALL OTHER COMPONENTS ARE FROM PREVIOUS ENGINE,BUT HAS HAD NEW EGR VALVE AND TURBO PUT IN, NOW WHEN STARTING IT FROM COLD OR EVEN AFTER HALF HOUR OF DRIVIN IT A HUGE CLOUD OF BLACK SMOKE WILL POP OUT
THEN SLOWLY CLEAR UP BUT WHILST DRIVING IT STILL APPEARS UNDER HIGH REVS AND SEEMS LIKE HASNT GOT FULL POWER BUT STILL DRIVES OK. ANYONE KNOW WHY??? THANKS
Currently in craiganderson's garage:
2002 vivaro 1.9 di
craiganderson is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by craiganderson
vivaro black smoke problem Engines woodsy28 2 7098 17th September 2010 09:43 PM
Sponsored Links
Advertisement
Old 18th September 2010   #2
Asterix
Asterix is
has no status.
Platinum member
Typing Test Champion
Asterix's Avatar
Re: vivaro black smoke problem
WOW, it is seen as bad netiquette posting in capitals especially in bold. I am sure there will be someone who can help you if you give it time.
__________________
Life is too short...laugh and enjoy it while you are able to
'24 hours in a day, 24 beers in a case. Coincidence? I Think not !!
Currently in Asterix's garage:
Renault Megane Scenic II 06 1.5dci Oasis in Eclipse Grey Metallic but it is not in a garage
Asterix is offline   Reply With Quote Quick reply to this message
Old 1st July 2011   #3
woodsy28
woodsy28 is
has no status.
Junior Member
I have a 2005 Vauxhall Vivaro I have the same problem with black smoke check there is no air leaks from intercooler pipes and make sure the small pipe from the intercooler manifold housing which goes to the Turbo boost sensor located R/H side of engine bulkhead is totally clear mine was blocked (rubber pipe and brass connector) this reduced smoke and increased power loads as I was towing my caravan to campsite struggled up every hill cleaned pipe out at campsite and flew home. Still some smoke under load but 75% better.
woodsy28 is offline   Reply With Quote Quick reply to this message
Reply
Tags
black, problem, smoke, vivaro
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
