16v 1600 renault scenic cam timming how to set - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 29th September 2010   #1
willemlucas
willemlucas is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Red face 16v 1600 renault scenic cam timming how to set
how do i set the timming on my 16v 1600 renault scenic 2005 my belt broke and now i want to fit a new one please help me
Currently in willemlucas's garage:
2005 renault 16v 1600 scenic
willemlucas is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by willemlucas
16v 1600 renault scenic cam timming how to set Engines 2 2549 29th September 2010 01:22 PM
Sponsored Links
Advertisement
Old 29th September 2010   #2
madnoel10
madnoel10 is
has no status.
Technical Supremo
Nominated 12 Times in 65 Posts
Nominated TOTW/F/M Award(s): 26
Re: 16v 1600 renault scenic cam timming how to set
I take you have checked for bent valves, etc?
To time the twin cam 16 valve engine you need a special kit.
Currently in madnoel10's garage:
Honda Civic 1.4l
madnoel10 is offline   Reply With Quote Quick reply to this message
Old 29th September 2010   #3
Scenic Fidji
Scenic Fidji is
has no status.
Edit
Posts: n/a
Hi and welcome to the forum.
you will need to buy or make a cam shaft locking tool.
As Noel says you need to check the valves.
Though I guarantee you will have bent most of the valves
The valve stems are so weak the just get bent out of the way as the engine keeps turning.
I have repaired a 1.4 and 2.0 16v Scenic with belt failure. Both had bent between 12 and 14 valves
Reply
Tags
1600, 16v, cam, renault, scenic, set, timming
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
