Burning smell from engine solved - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 30th September 2010   #1
Meerkat on acid
Meerkat on acid is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
I bought myself a 51 Plate Laguna 1.9Dci on Monday. Today i noticed a burning smell and after having my wheel ailignment adjusted this afternoon the "mechanic" told me "I think your clutch is on the way out due to the smell and supposed clutch slipping while driving it onto the ramp. I have driven it for three days over 100 miles through mainly stop start driving on the way and back from work and i thought the clutch was spot on. On the way home i tried the normal tests to see if clutch was slipping. Pulling away in second gear with handbrake on etc etc. Thankfully clutch seem fine. Also got my friend who knows his way around cars could not find a problom with it. I then opened bonnet which still had a burning smell. Did not take me long to find culprit responsible for smell. I took of the large plastic cover which covers most of the engine and the foam which was originally glued to the underside of it had come away and was basically sitting on the engine. Most of the foam was scorched black and in some parts had started to turn so soft and black it was like oil. Needless to say it took me ages to cleam most of the mess of the engine. Looking at it i would say most of the foam has slowly but surely fallen off over the years as i would say 30% has disappeared. Has this happened to any other Members and if so can the foam be bought seperate with the right adhesive etc or will the dealer try and fleece me by telling me the foam only comes as part of the plastic cover and will not be cheap lol At least it will be cheaper than a new clutch
Currently in Meerkat on acid's garage:
Renault Laguna 1.9Dci Privilege
Meerkat on acid is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by Meerkat on acid
Burning smell from engine solved Engines Meerkat on acid 13 3201 30th September 2010 10:06 PM
Sponsored Links
Advertisement
Old 30th September 2010   #2
qwakers
qwakers is
riding a r6 in the warm and dry, and using the company van for the rest.
Platinum member
qwakers's Avatar
Nominated 0 Times in 2 Posts
Re: Burning smell from engine solved
i just wouldnt bother. scrape the foam off and have done with it.
Currently in qwakers's garage:
Lag II sold ;-( Yamaha R6 04 black/Grey RangeRover 4.0v8 towcar and bobtailed discovery for offroading.
qwakers is offline   Reply With Quote Quick reply to this message
Old 1st October 2010   #3
Meerkat on acid
Meerkat on acid is
has no status.
Junior Member
Threadstarter
Hi I was thinking of that but not sure how much louder the engine would be without the foam as i know it is purely there to reduce the noise levels.
Old 1st October 2010   #4
Ralph
Ralph is
Laid back
Platinum member
Ralph's Avatar
Nominated 2 Times in 8 Posts
Nominated TOTW/F/M Award(s): 4
Try driving it without the cover see if you can put up with it.
Taking the one off my Clio DCi does not make a lot of difference.
__________________
Ralph's 4th law of motion states that any dropped object will immediately hide under a larger object.
If you find a fix for your problem please let us know it will help others.
Ralph Nr Fleetwood NW UK.
Currently in Ralph's garage:
Clio 15 DCi 80, Motomorini 3 1/2, Yamaha MT-07, LMS 5MT 3 1/2 inch Gauge.
Ralph is offline   Reply With Quote Quick reply to this message
Old 1st October 2010   #5
madnoel10
madnoel10 is
has no status.
Technical Supremo
Nominated 12 Times in 65 Posts
Nominated TOTW/F/M Award(s): 26
You could try replacing the foam using a can of "No-More-Big-Gaps" foam insulator filler. Then trim into shape using a knife.
Currently in madnoel10's garage:
Honda Civic 1.4l
madnoel10 is offline   Reply With Quote Quick reply to this message
Reply
Tags
burning, engine, smell, solved
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
