2005 megane vvti 1.6 16v starter motor problem - Renault Forums :: Independent Renault forum
Notices
RenaultForums
... Quick links
... Forum list
... Your dashboard
... Search the forums
... List new posts
... List today's posts
... List 0 reply posts
... Live post list (iSpy)
... Most viewed threads
... Special offers
... Members
... Member list
... Member map
... Member's gallery
... Who is online?
... Social groups
... Forum leaders
... Information
... FAQ index
... Garage list
...   Map version
... Glossary
... View our rules
...   Advertising
...   Privacy policy
... Contact us
... Feedback
... Fun stuff
... Arcade games
... Chat room
... Folding@Home
... Data
... Who drives what?
... Who supports who?
Engines
Reply
Thread Tools Display Modes
Old 7th October 2010   #1
VVTISPORTTOURER
VVTISPORTTOURER is
has no status.
Junior Member
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Hi, Please Help
I have a 2005 megane vvti 1.6 16v with a new problem. It sometimes takes a couple of times before the engine starts and it sounds like the starter motor makes a loud clicking noise after it turns the engine over but fails to start it. It finally starts on about the third go with no noise. Do you think the starter motor is on its way out?
Currently in VVTISPORTTOURER's garage:
2005 renault megane sport tourer vvti 1.6 16v
VVTISPORTTOURER is offline   Reply With Quote Quick reply to this message
5 Lastest Threads by VVTISPORTTOURER
2005 megane vvti 1.6 16v starter motor problem Engines VVTISPORTTOURER 4 4541 7th October 2010 10:14 PM
2005 Megane fitted new battery now have electric... Electronics 1 1985 7th October 2010 09:50 AM
Sponsored Links
Advertisement
Old 7th October 2010   #2
Scenic Fidji
Scenic Fidji is
has no status.
Edit
Posts: n/a
Re: 2005 megane vvti 1.6 16v starter motor problem
Sounds like the solenoid clicking which can be caused by dirty and poor connections. I would try tightening the connections on the starter motor and battery 1st.
Old 7th October 2010   #3
VVTISPORTTOURER
VVTISPORTTOURER is
has no status.
Junior Member
Threadstarter
Ok cheers i'll give that a go first before getting a new starter.
Many Thanks.
Old 7th October 2010   #4
Scenic Fidji
Scenic Fidji is
has no status.
Edit
Posts: n/a
Another thought it might be worth also getting the battery checked as well. 2005 it might still be on the original one?
Old 8th October 2010   #5
VVTISPORTTOURER
VVTISPORTTOURER is
has no status.
Junior Member
Threadstarter
Got new battery a few days ago a nice 075 one. I have double checked the connections on the terminals and there ok. I am going to clean up the connections on the starter today hopefully that solves it. Its done 65k maybe the solenoid thinks its done enough work.
Reply
Tags
16v, 2005, megane, motor, problem, starter, vvti
Quick Reply
Message:
Options
Post Icons
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Where are you?
What model do you own?
You must fill this field in
Where in the country are you?
What's your team?
Panic Button - On/Off Switch
Panic Button - URL Jump
http://www.Google.co.uk
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
